removing to plasic covers of the pillars...
'99 Acura 3.2TL
Hi, i wanna know how to remove the plastic covers of the pillars, and how to remove the roof, cuz i need to run wires there.
thank you
oh, i have a 1999 TL..
@cUr@-TL
thank you
@cUr@-TL
The B-pillar comes off very easily. First, towards the top of the plastic cover, you have to pop off the edges that hold it against the b-pillar rubber trim. Just take your fingers and pry it off. Once the top edges are loose, all you have to do is continue prying down to the base. Now it should be loose enought to just pull away.
To reinstall, line up the cover with the pillar and snap the top edges in against the rubber trim. The base portion should automatically realign itself to the pillar.
See how easy that was...
As far as the roof, I have no idea???
cycdaniel
12-17-2019 10:58 AM
HOWELLiNC
09-18-2015 11:12 PM
