removing door panel on tl 02
Old Feb 8, 2005 | 08:13 PM
aznboy's Avatar
do anyone have the instructions on how to remove the door panel on acura tl 02?????? thanks
Old Feb 8, 2005 | 09:19 PM
SilverIce2000's Avatar
do you mean the wood/silver/blackwood panels that are attatched on all 4 doors?
Old Feb 8, 2005 | 09:53 PM
DerrickM's Avatar
remove round screw cover behind door release lever
remove philips screw behind release lever (where cover was)
slide release lever assembly forward toward front of car & pull out
use small flat screwdriver to unhook metal rod by unhooking plastic clasp. remove assembly.
disconnect wire harness for door lock switch behind this assembly.
remove main screw from under arm rest (you'll see a hole in the middle).
remove sail panel if it's a front door. pull inward from top, then wiggle up and out.
pull door panel out from bottom, releasing friction clips.
lift panel up off of the door--it hangs over the metal where the window is.
disconnect all harnesses from inside, and you're done.
Feb 25, 2020 09:57 AM
BoricuaTL
Apr 8, 2016 01:08 PM
VA2000TL
Oct 2, 2015 08:26 AM
govtcheez
Oct 1, 2015 12:21 AM
CadiGTi
Sep 14, 2015 06:37 PM
