removing door panel on tl 02
remove round screw cover behind door release lever
remove philips screw behind release lever (where cover was)
slide release lever assembly forward toward front of car & pull out
use small flat screwdriver to unhook metal rod by unhooking plastic clasp. remove assembly.
disconnect wire harness for door lock switch behind this assembly.
remove main screw from under arm rest (you'll see a hole in the middle).
remove sail panel if it's a front door. pull inward from top, then wiggle up and out.
pull door panel out from bottom, releasing friction clips.
lift panel up off of the door--it hangs over the metal where the window is.
disconnect all harnesses from inside, and you're done.
BoricuaTL
04-08-2016 01:08 PM
