TSX: remove water guard in door or dynamat over it?
Old Mar 22, 2010 | 11:39 PM
Jottle's Avatar
I'm finally getting around to installing my avincar speaker set in my front doors. There's this white plastic water shield on the door skin. I want to put down dynamat on this area. Is it fine to just completely remove the skin and goop then install dynamat over the entire area (keeping the wire connections exposed)? Or do people generally leave the plastic skin on and put dynamat on top of that? It seems like the former is more common judging by the pictures I've seen on this forum. is there any risk in removing the plastic and replacing it with dampening material? Advice please!
Related question: Anyone use secondskin products like luxury liner?
Old Mar 23, 2010 | 09:07 AM
mattastick's Avatar
Second Skin Damplifier Pro is much better than Dynamat of any variety.
As far as removing vs covering the air vent, the problem with doing this is that that vent keeps the air pressure and all that roughly equal when you close the door. It's the same for the one in the trunk. So covering/filling the vent with make your doors harder to shut. Other than that though, there shouldn't be any other ill effects.
Old Mar 24, 2010 | 11:44 PM
Jottle's Avatar
So the only ill effect is that the doors will be heavier? I thought the plastic guard was for preventing water from entering the inner part of the door?
Old Mar 25, 2010 | 08:27 AM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
The white plastic sheet is for covering and protecting the window motor and inner door
Old Mar 27, 2010 | 10:25 PM
Jottle's Avatar
So what's the verdict? Remove it and dynamat over the space?
Oakes
Wash & Wax
Nov 12, 2015 09:34 PM
Laoch
1G RL (1996-2004)
Oct 2, 2015 03:27 PM
VA2000TL
Oct 2, 2015 08:26 AM
CadiGTi
Sep 14, 2015 06:37 PM
EE4Life
Sep 11, 2015 10:13 PM
