remote starters.
Old Nov 22, 2003 | 07:01 PM
asloudasitgets's Avatar
remote starters.
also i know it doesnt work on manuel trannys, but i was wondering how remote start works?
i mean you start the car from a ways away, then you reach the car. the car is already started so what do you just put the keys into the ignition? and restart the car? how does this work?
Old Nov 22, 2003 | 08:46 PM
Scott P's Avatar
Mobile Elec. Guru
it's pretty simple to explain. the brain of the remote starter takes power off of your 12v constant wire in your ignition bundle and uses it to give power to the wires of the car that are needed to start it. From there depending on what unit and what kind of set up you do it will "warm up the engine" and run the car until you either turn it off using the remote, hit the brake, or pop the hood (assuming you use a hoodpin). All that aside once you have started the car using remote start all you have to do is get into the car put your key in the ignition and turn it to the on position and tap the brake and the car will stay on and running and you can then go on your way driving
Old Nov 23, 2003 | 07:34 PM
NOX 3.2's Avatar
TL-SHAWD 6MT Rocks!
I bought a Remote Start called "Compu-Star" and that works with manual stransmission. It has a pager like control that has a reach of about 0.6 miles.
Old Nov 24, 2003 | 04:37 AM
eh!curaplus's Avatar
Team INSPIRE Canada
Does anyone know of an Acura Stock remote starter? I just want to stick with the same Brand, that's all!
Old Nov 24, 2003 | 10:47 PM
Black-n-Tan's Avatar
dont think acura makes one
i got the viper 790xv and its great in the summer and winter
Old Nov 27, 2003 | 12:12 AM
Team INSPIRE Canada
my only concern is getting one that works with the exsisting alarm. you'd think they'd come up with one
Old Dec 1, 2003 | 04:05 PM
ArN 2000 TL's Avatar
Moderator Alumnus
If you go to any reputable installer they can get it to work with the stock alarm. Mine is a DEI unit and works with my factory alarm. I hit unlock 3 times and the car starts.
To explain how it works is simple.....when you get in the car it is already running. If you step on the brake it will kill the engine and the car will stop running. However if you get in the car and put the key in the ignition and turn it to the 'On' position (you DO NOT crank it) then tap the brake pedal and the car is in your control.
Its definately a nice feature to have....sometimes in the winter i run into 7-11 or something and i want to leave the car running but just don't want to leave the keys in it so you can just tap the unlock button on the door 3 times and the car will remain running when you remove the key
Old Dec 2, 2003 | 12:52 AM
Team INSPIRE Canada
what kind of starter did you get?
if your's works with the stock alarm i might as well go for that one too!
does anyone know if we can hook up a motion sensor to the stock alarms?
Old Dec 29, 2003 | 12:19 AM
TlsNavi03's Avatar
NO BP FUEL IN MY
Is it true that since our keys are coded in order for the remote start to work a key has to be left in the car???
I don't like that idea, and thats why I haven't done it yet.
Old Dec 29, 2003 | 12:43 AM
njtls's Avatar
that sounds like a cool feature...what brand is it?
Old Dec 29, 2003 | 08:20 AM
Scott P's Avatar
Mobile Elec. Guru
i have been working on my alarm for some time (not necessarily installing it, but researching all the electrical wirings or the car to learn what would be possible to do from the alarm. here is what I have learned:
DEI alarms (i.e. Viper, Sidewinder, etc.) have negeative voltage inputs which given that the stock alarm has a negative output (I am assuming it does given Arn's testimonial) means you can install an alarm and keep the stock acura key fob.
next, now i'm not sure if this hold true for newer tl's but for the 99-00TL the myth about having to use a second key hidden in the dash to add remote start is just that, a myth. The ignition works off a chip with in the ignition cylinder the receiver a certain frequency from our key. This is called a transponder system DEI makes a module that taps into this system, determines the frequency and brodcasts it to the key cylinder to allow remote starting to take place.
Also alot of people worry about locating the alarm in the car and that it could be still suseptible to theft. The TL offters a lot of great hidiing places, the best I've found so far is under the center console and/or behind the radio. you don't have to worry about running the wires under the hood either. other than the siren (which can be replaced with a pezo indash horn) every wire needed to get the alarm/remote start to work is in the dash.
Old Jan 2, 2004 | 10:15 PM
larryr20's Avatar
Thanks for all the info! Im looking into the same thing myself. The thing I am worrying about is finding someone I trust to install it.
Old Jan 2, 2004 | 10:16 PM
larryr20's Avatar
Old Jan 2, 2004 | 11:18 PM
Z Factor's Avatar
Check with your local dealers as they typically have people to install aftermarket tints, alarms, etc., and are similar with the cars, and can interface the starter and factory alarm.
Good luck
datadr
Mar 23, 2016 01:39 PM
eastcoastguy
Oct 29, 2015 03:00 PM
Sue1910
2G CL Problems & Fixes
Sep 27, 2015 12:34 PM
saturno_v
Sep 27, 2015 08:13 AM
