Rattling
Old Sep 17, 2001 | 09:00 PM
BirjuP's Avatar
Rattling
Street, ValueTL, and all other expirienced members:
I installed two audiobahn 12s and now I have two autotek predator subs. I have gain on my 750 watt amp turned half way, and the rear deck vibrates extensively, along with the trunklid and everything. There are also multiple squeeking noises. I want to know what can I do to prevent these things. Thanks guys...later bj
Old Sep 18, 2001 | 10:22 PM
bdimc2001's Avatar
Talking
In order to fix the rattling in your trunk, try these...
Get some foam or weatherstrips from any local hardware store..home depot...Pop the upper trunk linings off and put the foam inbetween the wires...that's what's causing all the noise..I did that this weekend and I have hardly any rattles from the trunk unless I really crank it...and your license plates will rattle also...put some foam behind there too..that should solve it.
As far as the rear deck goes...I don't know how to fix it either..I'm also having some vibrations and rattles from there..even with the stock bose sub.
Old Sep 18, 2001 | 11:21 PM
my2sense's Avatar
f-a-b-o-l-o-u-s
I have the same problem. IT's really depressing as I paid alot of money for my system, and am now ashamed to bump it due to the "excessive rattle".
And to think, I used to make fun of ppl who had trunk rattle. Now I am one of them.. .
But the foam/weatherstrip idea is worth a try. Maybe this weekend.
Old Sep 19, 2001 | 03:21 PM
bigmonkey70's Avatar
for rear deck, you can remove the cover (from inside) and put some dynamat or foam on the body frame and put back the cover ...... Becareful with the GPS antenna if your TL is equiped with navigation.
By the way, for those who don't wanna pay too much for sound deadening, ... check here for alternative to dynamat ... only 1.35 for 10'X10" sheet.
http://www.partsexpress.com/pe/showd...=7081&CATID=35
Old Sep 19, 2001 | 03:24 PM
bdimc2001's Avatar
Can u do this for me when u r done?
Old Sep 19, 2001 | 03:26 PM
i finished my system ... just wait for ron to make the plexi for me ..... I can't find where the hell i put my foam .... hahahaha ... you see my basement right i opened the rear deck before to do my BEL radar dectector install .... not hard at all ...
Sure we can do it together ... if you like .... I'll let you know before i start stuffing foam
marcelft
Jul 10, 2018 06:17 PM
udelslayer
1G RDX Problems & Fixes
May 6, 2016 12:27 PM
CheeseyPoofs McNut
Oct 11, 2015 11:25 AM
jaynatlanta
5G TLX Problems & Fixes
Sep 15, 2015 11:08 AM
3GTLOwns
Sep 9, 2015 09:51 PM
