radio problems
Old Mar 25, 2009 | 05:26 PM
cl23's Avatar
radio problems
hi i disconnected the battery the other day because i was doing some welding..and when i hooked it back up now the radio doesn't work and a error-3 comes up is their a way to reset it or something? thanks for any help
Old Mar 25, 2009 | 05:28 PM
Anhedonia's Avatar
not sure if our stock radios are coded or not. but this seems to be the case.. your going to need to take your vin number and go to the stealer and theyll supply you with a code to input into your radio to get it functional again. its an anti-theft device.
DoubleSh0t's Avatar
You should have received a radio code with the car. It was on a card with the owner's manual. If not call your local Acura dealer with your VIN and they should be able to give it to you for no charge.
Old Mar 25, 2009 | 06:05 PM
on1wheel01's Avatar
+ 3 on that mine was written in the owners manual but me moms gave the car to me so I had a heads up. Ahhh can't beat free
Old Mar 25, 2009 | 06:07 PM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
You also can check behind the ashtray, inside the fuse box and in the side of the glovebox
Old Mar 25, 2009 | 06:14 PM
cl23's Avatar
got it called acura and gave me the code thanks guys..
Old Mar 25, 2009 | 11:17 PM
Anhedonia's Avatar
no problem
SidhuSaaB
May 30, 2020 12:40 AM
Puma Jim
20
Oct 20, 2016 11:59 AM
Kres43
1G RDX (2007-2012)
Oct 3, 2015 07:16 PM
tristann616
1/2G MDX (2001-2013)
Sep 22, 2015 11:40 PM
vanderveen44
ILX
Sep 16, 2015 10:51 AM
