radio problems
radio problems
hi i disconnected the battery the other day because i was doing some welding..and when i hooked it back up now the radio doesn't work and a error-3 comes up is their a way to reset it or something? thanks for any help
not sure if our stock radios are coded or not. but this seems to be the case.. your going to need to take your vin number and go to the stealer and theyll supply you with a code to input into your radio to get it functional again. its an anti-theft device.
You should have received a radio code with the car. It was on a card with the owner's manual. If not call your local Acura dealer with your VIN and they should be able to give it to you for no charge.
SidhuSaaB
05-30-2020 12:40 AM
Puma Jim
20
10-20-2016 11:59 AM
