Radio not working ; Fuse?
Hey,
so something happened can someone show me a diagram for the Fuses I can't find the radio one and my radio isn't working it's doesn't turn on for some reason is it the fuses or the wiring problems? Let me know.. It's so boring without a radio lol. :wish: |
Does anyone know how to solve this problem?
please! |
There is 2 radio fuses, 1 is located in the kick panel. The other is under the hood located on the passenger side toward the windshield. There is another fuse under the cover most likely causing an issue. (generally your clock will be messed up as well if it's the fuse under the hood). Thats how it is in mine.. just my 2 pennies
good luck bro |
Originally Posted by xxJ30A1xx
(Post 13694047)
good luck bro I think it's on the drivers side on the left panel by the steering wheel? |
Anyone else had or have this problem? :$
Guess no one knows the answer?
Radio problem
My radio quits intermittently too. Not a fuse problem and no other electrical issues, just the radio. The "fix" is to turn off the engine and turn it back on. Happens several times a day, or, I can go four or five days with no problem.
I hope after three years he found the fuse. If not, it's number 9, upper right, on the passenger side fuse panel. I just replaced it five minutes ago.
Man mine has done this as well nothing is wrong with the clock the radio went out changed every fuse .! BC this has Happened before and it was the fuses being blown but now idk what it is pulled the whole radio out and checked it for power and it had power but it won't cut on smh
I've botched the "code" entering process after i replaced my battery. I tried too many times to enter the code. Now I'm locked out. Im now on "err2". I have a 2004 tsx and I need to find the "backup fuse" and its number on the fuse panel. I see the diagrams but none identify the exact fuse number and location. I tried the "disconnect the battery and let sit for 5 minutes", and that didn't work. I tried the "leave the radio on for 1 hour" with ignition in ACC (accessories) mode. no joy. any suggestions?
Clock works and navigation code came up but radio isn’t working.
I recently jumped my car and connected the cables wrong and now my radio hasn’t worked since. I tried disconnecting my battery but only the code for the navigation comes up. The clock works and everything else but the 5 digit code for the stereo is no longer coming up. Someone please help.
Originally Posted by tjkazai
(Post 13690947)
Hey,
