Question for ROn or an alarm expert
Hey Ron Im hoping you could answer this. I've researched this forum and found some ideas but not a clear answer. I installed my own remote start alarm over a year ago. It was quite involved but I did it well. Everything works but when I want to auto start my car I must first press unlock, not because I want to unlock the doors but to deactivate the factory alarm, then press start and then I either lock it again with the remote or wait 3 sec and it does it automatically.
The reason it is a 2 button process to start is because I have a wire that sends a pulse signal to disarm the factory alarm but it is not connected. I do not know which wire disarms the alarm but does not unlock the doors. Im sure the wire exists but Im not sure where. Do you know where it is? I know if you put the key in the iginition it disarms the alarm or if you put it in the drivers key cylinder an turn it a hair it will disarm but not unlock. My wiring diagram says something about Disarm/Defeat in the passenger MUX box, is that the wire green/red? Can anyone tell me? Thanks!
Mobile Elec. Guru
Re: Question for ROn or an alarm expert
Well that is done for the remote start itself I have a DEI module doing that and it works. Starting the car isnt a problem, I just want to be able to start without unlocking the doors. Is it possible to disarm the factory alarm without using an unlock wire?
Does no one know what wire on the TL will accept a neg signal and disarm the factory alarm. It whether it unlocks the doors or not doesn't matter to me just as long as it deactivates the factory alarm so that the remote start can start the car without triggering the factory alarm. I tried putting that wire to the unlock wire and that works to deactivate the factory alarm but for some reason it triggers the aftermarket remote start alarm when I press the remote start button.
there is a factory rearm wire from your remote start to lock the car back up after it started, so you don't have to press lock on the remote if you can't find disarm no unlock on your car
Ok so I saw a three wire harness that looked like it may come from the cylinder. the middle wire had constant power and the other 2 showed posative when the key was turned. One to unlock, one to lock. So I assumed they send a posative signal. Am I wrong? would that wire you are reffering to disarm the alarm with a neg pulse without triggering the door locks in either direction?
Here is the wiring diagram and I circled what I think you are reffering to. Is this wire further in the door? Is it literally right by the key clynder meaning the best way to get at it is taking the door handle off? Because the 3 wire harness I found in the door had one blue wire which unlocks and one that locks but they were both a positive signal. Here is a diagram from my Helm manual. Why do I not see the wire you are reffering to? Please help
Originally Posted by vinha916
so if you arm alarm then you can't start? more likely you have the wiring wrong, the starter wired from starter module hook up to relay of your alarm .
navtool.com
31
11-16-2015 08:30 PM
navtool.com
09-25-2015 05:15 PM
