question for the builders and installers.....
Old Jun 13, 2005 | 07:23 PM
demolition_x's Avatar
Agean Blue Bishes
i want to make a false floor for my trunk so i can mount my amp flush. how do you attach the initial sheet of ply wood to the trunk floor. i was thinking of using the 4 pegs for the cargo net but what about the back where the fuel sensor is. i can't just rely those 4 pegs because the back peice is not going to be the same sheet. thanks in advanced guys.
Old Jun 13, 2005 | 07:42 PM
Jputt's Avatar
Audio Enthusiast
There are several ways to do it and it is going to depend on how you build the amp rack. Some people will drill right through the metal ie into the chasis. Sometime if you cut the piece of plywood to fit the contours of the trunk, you don't have to secure it with anything.
Old Jun 13, 2005 | 08:09 PM
Agean Blue Bishes
i def want to attatch it. i was thinking just get a sheet metal screw in the back. but is the fuel tank right against the trunk bottom or is there a gap. i guess i could just rely on the other 4 studs but i'll have to see.
Old Jun 13, 2005 | 08:21 PM
Jputt's Avatar
Audio Enthusiast
Test it out and see, then worry about anchoring it. That way you don't have any unnecessary screw holes in your trunk. If you do end up screwing into the metal, make sure to use some silicone caulking to ensure a water tight seal. PM me if you have any other questions. If you have some pics please send them my way so I can help you on the specifics.
Jput@mchsi.com
ttimberlak443
21
Oct 22, 2016 10:23 PM
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
DerrickW
Nov 15, 2015 05:52 PM
