power wire? behind seat?
Old Mar 7, 2004 | 09:46 PM
lsuracing_RENAMED's Avatar
Where does the power wire go through the back seat to the trunk?. Just wanted to get some tips b4 i toke the plunge. I ve looked around a saw places but what worked for you
Old Mar 7, 2004 | 09:52 PM
Hobo's Avatar
Flap.
well if you just lift up on the back seat you can kinda snake it through there on the side you ran it down, it goes under all the trim pieces and you cant see it at all.
Old Mar 7, 2004 | 09:55 PM
vsokolov's Avatar
remove the back seat and put some light in the trunk, where you see the light from inside just put the wire thru there, then go in the trunk and pull it easy just like that
Old Mar 7, 2004 | 10:12 PM
how do you remove the back seat?
Old Mar 8, 2004 | 08:15 PM
Hobo's Avatar
Flap.
you dont really need to remove it, if you just sit on the seat and pull up and tehn shove the wire in you will prolly get it maybe a little but a lot faster
Old Mar 8, 2004 | 09:03 PM
Red-CL's Avatar
Doin' da crack shuffle
http://www.geocities.com/gamesmgr/chod/acura/#Repair2
Feb 25, 2020 09:57 AM
Type S Zero
Feb 17, 2016 02:37 PM
pistacio
Sep 26, 2015 09:45 AM
2G-TL-Type-S-03
Sep 20, 2015 12:48 AM
Sep 17, 2015 09:01 PM
