power question(streeteffectz!!)
Old Jun 13, 2002 | 05:14 AM
asiankidd's Avatar
hi ron im trying to run a fat 4 gauge power wire from the engine bay to the trunk...where do you normally drill a hole thru the firewall to feel the power cable...any suggestions? thanks JON LERD
Old Jun 13, 2002 | 08:45 AM
Iggy's Avatar
Jon,
This where I went through the fire wall. I used 8ga but I'm preety sure you could get 4ga through.
amp wiring
Iggy
Old Jun 13, 2002 | 09:06 AM
StreetEffectz's Avatar
Jon, if you look up under the dash to the right of the steering column, you will see a black grommet with nothing in it. You can pop the hole right in that grommet. It's big enough for 0 guage wire by the way, so you should have NO problems
Old Jun 13, 2002 | 01:39 PM
asiankidd's Avatar
thanks alot guys i almost took the drill to the firewall!!!
Yikes
May 3, 2021 04:29 PM
Feb 25, 2020 09:57 AM
VA2000TL
Oct 2, 2015 08:26 AM
Sep 17, 2015 09:01 PM
datadr
Sep 12, 2015 09:12 PM
