power question
Old Oct 25, 2003 | 11:22 AM
fastcarz3's Avatar
power question
hey i just finished my system install which consists of an mtx 801D pushing 2 12" 8000's and kenwood 600 watt amp running my infinity kappa interiors. of course its dimming my lights and i also have a 1 farad digital top cap. Anyone have any suggestions (other then a new alternator) on how to reduce the dimming lights.
Old Oct 25, 2003 | 12:48 PM
GSteg's Avatar
upgrade the following wires with 4 gauge power wires
1. alternator to battery
2. battery negative to chassis
3. engine ground to chassis
Old Oct 25, 2003 | 09:41 PM
proaudio22's Avatar
-S namyaC-
GSteg is right, upgrade those wires - and I'm going to assume that you do have 4 awg wire already for the system. Don't bother changing you battery if someone suggests that, b/c that's not the solution, only a ghetto fix.
Upgrading the alternator is the best way - I mean you lights dim for a reason: there isn't enough power. A cap provides instantanious power for peaks - it's not really meant to provide constant power. You could have someone with a clamp DMM check and see how much power your system is pulling, and subtract that from what your alternator is putting out. Chances are, it's too much of a load. It's really not as bad as you think. You can probably pick up an Ohio Generator for $400 or so.
Old Oct 25, 2003 | 10:06 PM
fastcarz3's Avatar
thanks guys imma look into it and ya i got 4 gauge power wire
Old Oct 26, 2003 | 01:05 AM
wcb's Avatar
wcb
Make sure all ground points and other connections are clean. No paint, no rust, or dirt.
Yikes
May 3, 2021 04:29 PM
Feb 25, 2020 09:57 AM
VA2000TL
Oct 2, 2015 08:26 AM
Sep 17, 2015 09:01 PM
datadr
Sep 12, 2015 09:12 PM
