Power to a dvd
Old May 27, 2002 | 07:11 PM
Zeus's Avatar
Power to a dvd
How do you get power to a dvd player under the passenger seat? Do you have to get it directly from the battery? If so, what kind of wire should I use? The wire that came with the unit is only 2 feet long and has an inline fuse.
If not, where is the source of the power?
I want to power a blaupunkt me-1. It is 1.5amps.
I'd appreciate it if someone would give me a simplified answer.
Old May 28, 2002 | 12:13 AM
SilverKnight's Avatar
Retired. Not available.
You can get power from the seat motor's wires, however, I wouldn't touch them since it's hard to access them. You can get power by tapping to the power outlet's wire in the center console or connect your dvd player's wire to a power plug (sold at Walmart, K-Mart, Auto Zone, ect.) and plug it in the power outlet. You can also use the way I posted in your other thread. Good luck.
Old May 28, 2002 | 12:49 AM
Zeus's Avatar
Cool
Three questions:
1. What does the power plug look like?
2. What power outlet does it plug into?
3. When you say I could just tap into it, does that mean just splicing?
Again, thanks for the continuing help. It is hard for me to understand these installs and I appreciate the patience.
Old May 28, 2002 | 10:13 AM
Re: Cool
Originally posted by Zeus
Three questions:
1. They look like the "power plug", the type that you plug in Cigarette lighter outlet.
2. The one next to "not an ashtray" thing or inside the center console.
3. Yes, but you have to know how to remove the center console and basic electrical knowledge.
Old May 29, 2002 | 03:05 AM
Zeus's Avatar
Is step 3 like this?
The way I think it would work is as follows. I remove the panels to get to the cig lighter wires in the center console (I found another thread with instructions). Then I remove a section of the insulation from the red wire. I intertwine the power wire of the dvd to this section and cover with electrical tape. Then I ground the dvd player to either the black wire with the same procedure or to unpainted metal. Is that right?
Is there any other basic electrical knowledge I need?
Old May 31, 2002 | 06:38 AM
Austin519's Avatar
SilverKnight:
Why is he doing this instead of just tapping the battery directly?
Austin519
Old Jun 3, 2002 | 01:35 AM
Because he is gonna have a hard time running the wire from the battery through the firewall. Look at his sig and you will understand. Also, the solution is the simplest way to go.
Old Jun 3, 2002 | 05:06 AM
NOVAwhiteTypeS's Avatar
I have a apex-md100 and it has 12volt power just like an amp.
Old Jun 8, 2002 | 07:51 PM
Austin519's Avatar
SilverKnight:
Ha ha ha I see.
Austin519
Jul 16, 2017 07:33 AM
spudweb
May 22, 2016 02:39 PM
knight rider
Mar 4, 2016 08:59 AM
RadiantCycles
ZDX
Sep 26, 2015 09:18 PM
