Pics: H.o. 160 Amp Alternator!
Re: H.O. Alternator
Hey Kman,
Where did you buy the alternator from? I was looking into buying one for my car, but this might be too small for my system. I am running well over 2000 Watts in my car and I need something more powerful. I was looking around and found a shop that will build me a custom built alternator that will generate 200 A and 120-130A at IDLE. The only problem is that he is charging $900.00, not a bargain at all. I need one that can be custom built for my car and still be cost effecient. Can you please recommend a place where I can purchase one that is very powerful, but also economical.
![Exclamation](https://acurazine.com/forums/images/icons/icon4.gif)
they are in texas...ask for patrick! the alternator is in! running great!!! bolts right into the stock denso application. i had to go to pep boys and buy the next size belt down from stock .5" less. the belt was loose and squealing@ low rpm's / and a/c on. now it 's perfect! get the 4 gauge wire with it. i think the whole thing with shipping was $200? the alternator was like $160, wire $25, shipping! they give you like 15 ft of 4 gauge you only need like 6ft, you could propably get a shorter wire for less$ somewhere else? hope that helps!
kman
![Cool](https://acurazine.com/forums/images/smilies/cool.gif)
tthey sure do! i don't know who you spoke with but,
Originally posted by 96TL
Kman, I called them today and some guy told me they dont make them for Acuras. Patrick was out today. Should I speak with him?
![Confused](https://acurazine.com/forums/images/smilies/confused.gif)
96TL...Isn't that the company Austin5|9 found and did a groupbuy with? You gonna give him props? ![Wink](https://acurazine.com/forums/images/smilies/wink.gif)
kman156...That more hp draw isn't true...it just means they either 1) put in more copper or 2) built a more efficient one. I was following Austin5|9's on www.acura-tl.org and since they used a small case instead of a large case...there's no way it was added draw on the engine...I mean the copper is going to be heavier but that's like maybe 1 hp difference, maybe. I think they just build more efficient ones. They're the group that's used by a lot of car audio companies...ie. Rockford Fosgate.
TLRunner
TLRunner
InFaMouSLink
10-30-2015 09:43 AM
SinCityTLX
55
10-11-2015 01:20 AM
