New subs!?!
New subs!?!
Ok so i made a thread about sealing my trunk that got WAAAYYY off topic into other catagories sooo...i am making a new one to ask a different question
i am probably going to sell my 2 jl w7 12's and get?? i dont know...i am torn between the FI q 15 or the AQ 15 or any other 15 for that matter...i dont really know how to make up my mind
im looking for 1 sub perfered 15 that can play at least 2k watts all day and is pretty dam loud... also i would like to be able to compete with this sub and do pretty good
ok so any help is appreciated!!!!
What are you trying to get that your W7's don't do?
If you can wait, a Tempest-X by DIY Cable is an awesome sub and a huge bargain for what you get. I have one in my home theater and love it.
dont get me wrong i love my w7s they are just not subs to compete with from what i keep hearing also i have zero room in my trunk and the specs still call for a bigger box...
i cant switch down to one sub because my amp doesnt have the ohm load or whatever...jl made it to where to get the best performance out of a single sub you have to buy their over priced 1000 what amp at least that was what i read and was told
so...i am on the look out for a great 15 and i will check in to DIY i have never heard of them before
If you are looking for an SPL oriented setup, then check out Incriminator Audio.
Good luck with your decision!
The DDZ series is a burp sub. It's good for burps at comps. If you try to play music on it, you'll kill the sub... It's not what it's made to... Those old Adire's are no joke... So if that DIY sub is made by the guy that designed it and with similar (or better) parts, that thing should be a beast. Mike, keep in mind AQ=DD. The people that own each company are the same family. If you order something from AQ, it comes in a DD box. So keep that in mind if you're looking at a DD.
Other subs to look at: RD Alphamax or Alpha V.2 with flatwind coils option. I have a V.2 12, and it's a beast.
Cascade Designs Omega. The guy that designs/manufactures/sells them says they'll handle 3300w daily and there's a guy doing 155+ with 2 15's and ~7kw... So they get pretty loud...
Atomic APX, Mach 5 SPL are also good choices...
that video is freaking crazy i for dam sure am going to check into to this whats their main web site so i can check their products
Unfortunately they are out of stock on the Tempest-X, their 15" sub. However they do have 12" (Shiva-X) and 18" (Maelstrom-X) subs available.
Those Brama's are no joke... As for that Parthenon motor, it looks like DD's Z motor a little bit. This one looks like it would work daily though, and since the Z's are burp only...
As for RD's site, here you go: http://www.rdaudio.net/index.htm
is the HDC315 burp only?? and if it is which is the better sub the HDC2.515 or the Alpha v.2 15?
the AQ HDC2.515 seems a lil weak imo but i also dont know to much about subs either...
Since you're looking at 15's, check this out: http://www.caraudioclassifieds.org/f...play.php?f=110
One of the guys over there is doing a 15" challenge, where he's testing any/all 15's he can get his hands on.
As for the HDC3, it's a very solid dub. The SDC2.5 is more of an entry level sub. The HDC3 is where you're going to want to look if you're thinking AQ. As for the difference between the Alpha and the HDC3, the Alpha will hit lower. The AQ's like higher tuning, but still do alright for the lows, whereas the Alpha slams when tuned low...
your call dude... At this point, it's all a personal choice... You can wait for the 15" challenge, and then judge based on that, or you could buy whatever you want now... It's your call...
I just talked to Matt (the guy doing the 15" challenge) and he said he's just waiting on all of the subs to come in. He's hoping to get everything started by next week. I really want to see the results, as there are a ton of sick subs (some with more hype than others) that will be put to the test...
i dont think i will be ready for the coil yet im not to crazy about 2 altornators and 3 to 4 batteries not yet at least
so without the coil which is better the AQ or the FI? and what would be a good amp to push it? one of AQ's?
InFaMouSLink
10-30-2015 09:43 AM
kb1rl
09-30-2015 10:17 AM
