need help with tft mobile monitor
Do you get a "ON" light? This would indicate a power problem, check power feeds including fuse.
Do you see a faint image in the LCD (looking very close, although not visable on all displays) it could be your flourscent backlight is not working. TFT's use a high voltage backlight and this would be a transformer problem.
What brand or model is this?
Re: need help with tft mobile monitor
What are you using for a video imput? DVD, VCR, playstation? Make sure its getting a video signal. If the backlight is on then its not a power problem. If you're sure that its getting a video signal, then most likely the monitor is bad.
Originally posted by StreetEffectz
Is the screen appearing totally black or totally white by chance? There is a ribbon cable that goes from the circuit board to the monitor that MAY have come loose.
blacktsxwagon
Oct 27, 2015 10:12 PM
AcuraKidd
Sep 25, 2015 11:18 PM
