Need help quick!
Old Jul 9, 2005 | 03:09 PM
Lord Helmet's Avatar
I'm here in spirit...
Exclamation Need help quick!
In the pic of the wiring diagram seen here: http://silverknight.clickhere2.net/sound.html
Is the "Constant power" my remote amp turn-on lead or should I use the "Radio Switch" for that. I'm in the middle of working on this right now and I could use some immediate help. BTW, I'm in a '01 CL-S (2nd Gen) w/ factory Bose amp. Thanks millions!
Old Jul 9, 2005 | 04:04 PM
Anyone???
Old Jul 9, 2005 | 04:37 PM
optomos's Avatar
I=X - optomos
14. Remote turn-on power from amp
If you keep the factory head unit, this lead only provides about 9 volts, and will not pull
an efficient relay. (I couldn't get it to trip a 12V relay drawing 60mA, or a 9V relay
drawing less). I made the mistake of running my cd changer and
line driver/EQ from this lead and couldn't understand why it didn't sound great).
Sadly, I don't know the solution to remote turn-on. I think the answer is a 5VDC relay
on the remote lead. I used a relay on the switched power to the Bose EQ (Yellow wire,
smaller harness), and it introduced terrible noise into the subwoofer. (I'll try the
smaller relay on the main remote lead tomorrow).
Heres a link to the topic. Also look toward the bottom of the post for an update. I hope this helps
https://acurazine.com/forums/showthr...hlight=turn-on
Old Jul 9, 2005 | 08:32 PM
elduderino's Avatar
VP Electricity
Yeah, "radio switch" is the Honda term.
You could just use one of these:
http://www.cardomain.com/item/PERLVT2
MilanoRedDashR
Oct 8, 2015 10:30 AM
KBTypeS
25
Oct 1, 2015 04:49 PM
mshipon
2G CL Problems & Fixes
Sep 28, 2015 12:14 PM
TLguy42
Sep 26, 2015 11:27 AM
