Need help quick!
Old 07-09-2005, 03:09 PM
I'm here in spirit...
Lord Helmet's Avatar
Exclamation Need help quick!
In the pic of the wiring diagram seen here: http://silverknight.clickhere2.net/sound.html
Is the "Constant power" my remote amp turn-on lead or should I use the "Radio Switch" for that. I'm in the middle of working on this right now and I could use some immediate help. BTW, I'm in a '01 CL-S (2nd Gen) w/ factory Bose amp. Thanks millions!
Old 07-09-2005, 04:04 PM
Anyone???
Old 07-09-2005, 04:37 PM
I=X - optomos
optomos's Avatar
14. Remote turn-on power from amp
If you keep the factory head unit, this lead only provides about 9 volts, and will not pull
an efficient relay. (I couldn't get it to trip a 12V relay drawing 60mA, or a 9V relay
drawing less). I made the mistake of running my cd changer and
line driver/EQ from this lead and couldn't understand why it didn't sound great).
Sadly, I don't know the solution to remote turn-on. I think the answer is a 5VDC relay
on the remote lead. I used a relay on the switched power to the Bose EQ (Yellow wire,
smaller harness), and it introduced terrible noise into the subwoofer. (I'll try the
smaller relay on the main remote lead tomorrow).
Heres a link to the topic. Also look toward the bottom of the post for an update. I hope this helps
https://acurazine.com/forums/showthr...hlight=turn-on
Old 07-09-2005, 08:32 PM
VP Electricity
elduderino's Avatar
Yeah, "radio switch" is the Honda term.
You could just use one of these:
http://www.cardomain.com/item/PERLVT2
MilanoRedDashR
10-08-2015 10:30 AM
KBTypeS
25
10-01-2015 04:49 PM
mshipon
2G CL Problems & Fixes
09-28-2015 12:14 PM
TLguy42
09-26-2015 11:27 AM
Quick Reply: Need help quick!
