TL: Need Help with my Audio Upgrade
Old Nov 22, 2010 | 02:55 PM
GreenWitDaChrome's Avatar
So i have a 99' TL and i want to upgrade my audio all the way. i want to replace all 4 speakers in the doors the one all the way in the back and replace the stereo. i want to get an in dash Stereo. i was looking at some brands but i havent decided yet. i also want to replace the sub in the bak with a 10 inch or 8 inch. any suggestions on wat kind of speakers and sub to get?
Old Nov 22, 2010 | 03:24 PM
mattastick's Avatar
Budget and goals for the system?
Old Nov 22, 2010 | 06:39 PM
on1wheel01's Avatar
+1 on that your ? is to vague
Old Nov 24, 2010 | 10:05 PM
Flipster23's Avatar
Don't replace the sub in the back just get a enclosure and you can only fit a 8" shallow mount in there anyway
x3 budget on your audio
Old Nov 29, 2010 | 09:19 PM
My budget is around $1000 including an extra battery.
i want to save some trunk space so i wanted to replace the sub in the bak with a memphis.
im looking at the biggest door speakers i can get without having to cut my doors up.
and as far as the stereo im looking at a Pioneer In Dash
Old Nov 29, 2010 | 09:33 PM
2nd Gen 02 Type S's Avatar
question on this how heard is it to get to the door speakers. And i was told that once u pull the stock bose cd player out the sub n the back no longer works
Old Nov 29, 2010 | 09:39 PM
Jimmay's Avatar
When you say replace the sub in back do you mean in the deck? Because this probably isnt a road you want to go down. Youd be free airing the sub which unless its made for it probably wont sound good.
Why memphis might i ask? If you want to save some money try looking for some used stuff.
As for the speakers heres a thread i found on here https://acurazine.com/forums/audio-video-electronics-navigation-22/speaker-size-174536/
Im very satisfied with my Crescendo comps(if you wanna see them search for my thread.) and they should be just drop ins for your door. Youll just need to mount the tweeters someplace or you can mount them on the speaker.
Old Nov 29, 2010 | 09:55 PM
As for the speakers heres a thread i found on here https://acurazine.com/forums/showthread.php?t=174536
My brother used to run nothing but memphis and audiobahn in his car and i liked how it sounded. plus i can get a deal on some brand new memphis door speakers for about 60 a pair.
i saw ur pick and wat are u pushing?
Old Nov 29, 2010 | 09:57 PM
damn i didnt know that. i might just leave that alone then.
rockford fosgate has some subs that can be without a box.
plus ive seen many cars with subs facing inside with the magnet hanging.
Old Nov 29, 2010 | 10:28 PM
eggyhustles's Avatar
uhh
x794 $159 http://www.amazon.com/Kenwood-Kdc-x7.../dp/B003TNMD9Q
rsd $89 http://www.woofersetc.com/p6952/RSD6...ker-System.htm
1000c4 $239 http://www.crescendoaudio.com/produc...roductid=17516
2 10" fi x $130 https://ssl.perfora.net/www.ficaraud...iew.shopscript
Leaves enough for box, deadening, wiring, and a batt
Old Nov 29, 2010 | 10:36 PM
Jimmay's Avatar
By pushing what do you mean lol. and eggyhustles, once again you design someone an entire system that will sound great, for cheap. How do you do it?! and i dont think ive ever seen you recommend the same setup twice.
Old Nov 29, 2010 | 10:55 PM
Flipster23's Avatar
u want to save room in ur trunk just get a custom box then but u will not be happy with replacing the bose sub
the biggest door speakers u can probably get are 6.5 not to sure though
as for your question 2nd gen 02 type S door speakers are super easy to take out there is a DIY on it and you there is a way to keep its in the audio section
Old Nov 29, 2010 | 10:58 PM
Flipster23's Avatar
if u really wanna keep the sub in the deck, that thread below is how u can keep the factory sub with an aftermarket deck
https://acurazine.com/forums/audio-video-electronics-navigation-22/keeping-factory-sub-when-adding-aftermarket-headunit-99-03-tl-326253/
Old Nov 29, 2010 | 11:03 PM
REDmanCL-S's Avatar
i actually have an in dash pioneer dvd player and noticed all the speakers work accept the sub. i dont know what the hells wrong with it. any suggestions...
Old Nov 29, 2010 | 11:06 PM
Flipster23's Avatar
look at the link above that I posted it tells u how to keep ur stock bose sub with an aftermarket deck
Old Dec 1, 2010 | 10:47 AM
ha me either and now my passager side stopped working and my 2 n the back i just blow listen to Rick Ross B.M.F lol
Old Dec 10, 2010 | 01:39 AM
jwp1013's Avatar
When I put in my Pioneer dvd hu the factory sub still worked take a look at that thread it should help you out. I just didn't like the distortion of the facotry sub and speakers when they were being pushed hard, so they couldn't stay. Take a look at some 6.5" Focal Polyglass speakers. I am a huge fan of their speaker, once you hear them you will fall in love. Look around on craigs list and you can find some really good deals every now and then. JL audio sub(s) and amp will sound amazing and normally there is a good selection of used products.
Sounds like you need to figure out what exactly your goal is for the car. How good of sound you want. I did my car in stages h/u, then subs, then speakers. Easy on the wallet but I now have more than enough power and amazing sound quality.
If you go for quality over quantity as far as the amp you wont need an extra battery. When I first put my subs in the amp wasn't getting near enough power and would keep shutting off. I just cleaned off all the corrosion from the terminals and all of the wires. then just ran to autozone and picked up a stinger connector($20) for the positive terminal and haven't had a single problem since and that was over a year ago.
Jul 16, 2017 07:33 AM
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
ValdezQ26
Oct 1, 2015 04:48 PM
thegipper
Sep 28, 2015 01:01 PM
