Need help choosing amp
Old Apr 26, 2005 | 10:59 PM
Blazin_TL's Avatar
Registered User
ok i need help choosing the correct amp for my system.. im going to be running two 12'' kicker L7 in a ported box. i want to get the most out of these subs and as for budget i dont want to spend more than 600 dollars.. any help will be appreciated
thanks!!
Old Apr 27, 2005 | 10:12 AM
jpswanberg's Avatar
jl 500/1, circa 250 to 300 watts per sub; all the filtering you'll ever need; remote bass control optional.
Old Apr 28, 2005 | 01:37 AM
vidoprof's Avatar
those subs are going to be way underpowered with any of those amps.. $600 is just not enough to get the most out of those subs....
you really should be putting like MINimum 500W to each sub.. MINIMUM.. 1000W is about right.. EACH.
i would say the 1000 JL is a good choice for 1 of them.. but if you really cant afford to power them the right way maybe put that 1000/1 JL to both for now until you can get another one.
You could get a DLS A4 and put it on them.. DLS is very underrated with their stuff and that should power them nicely..
Maybe a zapco refernce 1000 would work too.. All are CLOSE to the $600 limit you have ... you might have to spend a LITTLE more.. but well worth it to get the better amp... It will give you more power (usually as they are underrated) and it will be much cleaner power.. which means you can get more out of the amp.
Ryan
Old Apr 28, 2005 | 02:00 AM
ou sig's Avatar
Boomer SOONER
Go with the Kicker amps - really the best bang for your buck out there with great sound quality and reliability. My dad still has his original 3 amps in his truck - they are 9 years old! and have never missed a beat, nor have any of the Kicker amps that I have had (I have gone through 6 with my different systems). You can get the KX 1200.1 on ebay for around $450. That will be all the power they would want. But you do realize your trunk is going to flop around like shit with that much bass right? much less you wont have any trunk space...but at least you will have some BOOOOM!
and Kicker amps are also under-rated. My amp is rated at 600 watts RMS into 2 ohms mono - but it was tested at 738 watts RMS.
here is a link - I have purchased a few things from this guy before - very good to deal with.
http://cgi.ebay.com/ws/eBayISAPI.dll...769664325&rd=1
Old Apr 28, 2005 | 02:45 PM
NYZGREATST's Avatar
Sig Rho's Finest
how bout a diamond audio
(1) DIAMOND AUDIO D5 D51200.1
RMS Output Power 1200 Watts x 1 @ 1 ohm mono
2400 Watts x 1 Peak
Freq Response: 10Hz-500Hz
Signal-to-Noise Ratio: 100dB
THD: 0.03%
Length: 14.5"
Width: 12"
Height: 2.75"
p.s. im tryin to sell this! its brand new
Old Apr 28, 2005 | 09:37 PM
Blazin_TL's Avatar
Registered User
i dediced that the L7 is going to be way too much bass..so i decided to downgrade to 12 inch L5 insted.. i think these are rated at 600rms a pc...
how much u sellin the amp for bro?
Old Apr 28, 2005 | 10:58 PM
elduderino's Avatar
VP Electricity
Are you choosing your woofs by their power rating?
Old Apr 29, 2005 | 11:15 PM
vidoprof's Avatar
Apparently, or the fact that he doesn't really know that kicker makes crap now. Well not crap.. but they are NOT like they used to be.
the 9 year old amps were VERY GOOD.. Even their stuff 5 years ago, but after that they started to go downhill.. and their subs nowadays are NOT the quality they used to be.
But to each his own. Like I said earlier.. IF you are going to NOT be putting enough power to them they will sound like crap. Better to overpower them with a CLEAN signal then underpower them.
Ryan
Old Apr 29, 2005 | 11:34 PM
Blazin_TL's Avatar
Registered User
as the title says.. i need help choosing an amp... i said that i decided to go with the L5 12'' which is 600 rms a piece, making it easier for somone to help me find a decent amp for my budet..
we all have our opinions on what we like and dont.. my buddy has a pair of 10 inch l7s and im impressed with the sound... like u said to each his own
Old Apr 30, 2005 | 08:25 PM
vidoprof's Avatar
For $600 you can probably get the 1000/1 from JL. Pretty close to the power rating of your subs. Just curious how much were the subs? Why i ask is that you might be able to get a better sub from some advice here that will match the amp better, then the other way around.
Better to get a better amp and have WAY TOO much power then a good sub and underpower it. Cause later you can upgrade the subs easier, but upgrading the amp will usually cost you more.. Plus the amp is the biggest factor IMO in an install. Get the BEST AMP you can afford.. and work around that
Ryan
Old Apr 30, 2005 | 11:23 PM
Blazin_TL's Avatar
Registered User
Ryan
well i didnt get the subs yet.. my style of music is mostly rap and i like to have a decent amout SQ but SPL is a bigger factor for me.... my buddy has two 10 inch L7'S and its perfect for me... i usually make bad decisions when comming to my system, and always buy shit that ends up sounding horrible, so i figured this would be the way to go since ive actually heard it and like how it sounds... the thing is i already have a kicker box that i got from a friend of mine who sold the subs and amp and never got rid of the box so i took it off his hands.....thanks for the help
Jul 16, 2017 07:33 AM
InFaMouSLink
Oct 30, 2015 09:43 AM
joflewbyu2
Oct 8, 2015 11:16 AM
iesu3423
Sep 29, 2015 06:38 AM
