Need Help With Audiobahns
Old May 23, 2004 | 10:57 AM
DjKiwi's Avatar
Question Need Help With Audiobahns
Hey guyz, what's up?
I'm running 2 10" Audiobahn AW1006T subs with a 1300HCT Audiobahn amp, as well as I'm keeping the stock deck. Any suggestions on wiring up the system and taking apart the centre console?
Old May 23, 2004 | 11:15 AM
fsttyms1's Avatar
you will need a line out converter and tap into the sub wires (behind rear seat)
here is a link to taking apart the dash http://www.abunchofcars.com/diy_page...er_console.htm
oh and first chance you get, do your self a favor and get a aftermarket HU
Old May 24, 2004 | 08:48 AM
DjKiwi's Avatar
Thnx a lot...the only reason I'm not gettin a after market h/u...don't wanna attract attention to the interior...too many punk kids runnin around stealing sh*t
Old May 24, 2004 | 11:11 AM
shogun's Avatar
im the best
you could alternatively, run a remote, power and ground and tap the lines before the stock amp and avoid the loc. either way you need to remove the back seat.
Old May 25, 2004 | 06:42 AM
DjKiwi's Avatar
see I'm new at this...so what's "loc"...and how do I remove the backseat?
Old May 25, 2004 | 01:18 PM
keeena's Avatar
LOC - line output converter. It converts from a high-level to low-level signal. High-level signal is a signal which would power a speaker (amp to speaker). Low-level is a pre-amp signal. LOC lets you take speaker output from factory amp and step it to a low-level signal which can then be input to an aftermarket amp. As someone else mentioned, there is a stock low-level input that goes from the front of the car to the factory sub amp in the rear. So you could just splice into this low level input and add RCA ends to them. Or you could take the stock sub amp output and use an LOC.
Back seat - Remove 1 10mm(?) bolt above driver side lap belt (you have to get inbetween the seat bottom and seatback with a ratchet...poke around a bit and you'll see it). Then the seat bottom lifts out (friction fittings on the front edge of the seat bottom). Then remove 3 more 10mm bolts at the bottom of the seat back (one each near the doors and another near the passenger side lap belt). Then lift up to release the friction fittings at the top of the seat that go into the rear deck and pull the seatback out. You'll need to move the seat belts out of the way to get it all the way out. It can be a little bit of a pain to get the fittings at the top of the seat to come out and stay out. ie. as you release 1 side of the seatback, it will tend to pop the other side back in. Having 1 person on each side helps, but isn't necessary. Do it once and you'll definitely get the hang of it.
Old May 25, 2004 | 04:21 PM
DjKiwi's Avatar
Alright...thanx a lot
Old Jun 7, 2004 | 05:27 PM
DjKiwi's Avatar
How would I wire the amp to my stock deck? Anybody got any suggestions?
Old Jun 7, 2004 | 07:48 PM
VTEC11's Avatar
You mean just wiring the amp for the sub? If so, you don't really need to take the dash apart since you'll be tapping the signal wires that are located by the stock sub amp (behind the rear seat).
check this thread below, someone just added a sub/amp using this same method.
http://www.acura-tl.com/forums/showthread.php?t=82766
Old Jun 20, 2004 | 02:25 PM
DjKiwi's Avatar
Sorry, I didn't mean to the deck...I ment power wire
Old Jun 20, 2004 | 04:28 PM
NYZGREATST's Avatar
Sig Rho's Finest
you dont run a power wire to the stock deck. you have to drill a hole through ur firewall and run the power wire through there directly to the battery. make sure you have a inline fuse within a foot of the battery. the only thing you have to run to the headunit are the RCA'S and the remote wire.
Old Jun 21, 2004 | 09:29 AM
DjKiwi's Avatar
Aight...thnx...does it show that I'm new at this?....lol
Old Jun 22, 2004 | 03:24 AM
NYZGREATST's Avatar
Sig Rho's Finest
its all good, its all a learning experience
Old Jun 24, 2004 | 08:20 AM
DjKiwi's Avatar
thanx for all the help...if you guyz have any tips...please let me know...I appreciate it
Old Jul 6, 2004 | 05:16 PM
DjKiwi's Avatar
to those who care.....the box for my subs is done....I'll upload pics if u guyz wanna see em.....now I just need some help with my amp....it's the 1300HCT Audiobahn amp....I'm not gettin an aftermarket h/u...so how the help do I wire the remote wire to my car?
Old Jul 7, 2004 | 01:05 AM
shady's Avatar
Hey DJ,
R audiobahns any good? im thinking about getting 2 Audiobahn Alum12Q for my car but some one mentioned in another post that they are not worth buying any that they tend to skip beats when it comes to fast bass i.e. they are only good for rap.... info much appreciated...
Old Jul 7, 2004 | 08:25 PM
mikelee223's Avatar
What kind of LOC did you get? Or did you use it? Do you happen to remember what color wires are what? I'm looking for a LOC, I dont know which one to get. There is 55w and 30w MAX input that i'm looking at. Help?
Old Jul 8, 2004 | 04:14 PM
DjKiwi's Avatar
to tell u the truth....I'm a first time user of Audiobahns...I heard em at a carshow and they sounded pretty good....those other guyz know better.....so if they saying don't bother then don't....sorry....the LOC I used, I have no clue bout the specs...my cuzin is the "big audio guy" and he grabbed it for me, I haven't taken a look at it yet...but I will in the next few days
Old Jul 12, 2004 | 05:43 PM
DjKiwi's Avatar
how do I wire my amp to the fuse box?...help please
Old Oct 1, 2004 | 09:13 AM
DjKiwi's Avatar
For those who give a sh*t, my system's done...I just have to cover my box in white vinyl...if you guyz want pics or anything...let me know...ez
LIPPSTUH
Apr 2, 2008 04:43 PM
Zeeshan
Sep 19, 2006 12:53 AM
yunginTL
Sep 8, 2005 08:45 PM
msdosp1mp
Jun 6, 2005 11:20 PM
NFLblitze1
17
Jan 24, 2005 04:05 PM
