Need Hellpp Quick???
Old Feb 28, 2002 | 06:43 PM
aznboyz2000's Avatar
Question Need Hellpp Quick???
can some body tell me how to take out the center console? any website with pic? or is there any easier way to locate the harness?? i need the help quick because i car is apart right now, and i only have this weekend to do it. thank in advance
Old Mar 1, 2002 | 02:36 AM
bebber's Avatar
easy to do
You can easily remove the center console.
1)Open your center console compartment fully.
2)Remove the two pieces of fake wood trim that run along the sides of the console. Just dig your fingers underneath and pull them straight up as you wiggle them.
3)Look at the bottom of your center console compartment and remove the carpet insert. You'll see two screws which you'll need to remove.
4)Remove the two screws midway along the center console that were hiding underneath the wood trim.
5)Grasp the center console from the rear, and pull it up. It should slide off.
6)Reach in and disconnect the wiring harness.
7)Take the center console out of the car and store it in a safe place.
eh voila
Old Mar 1, 2002 | 03:57 AM
thank bebber, now i got another question, how do u take the factory deck out?? well.. i really don't need the deck to be out, if it not needed, all i need is how to get to the harness of the deck unplug? so i can hook up to my LOC {line out converter} and should i install my LOC before or after the bose equlizer? and for people have a 1 inch spacer for the speaker, do you glue them to the door?? if so what type of glue you using?? ohhhh.... one last thing what color is the remote turn on wire? i know...... i know..... i ask alot of question, but this is my first time install on a TL, i had install on my accord before, but i never expect to be this hard on a TL and i'm working on my own because i'm enjoy hooking it up and have pride on my work, it's a hobby thing for me thank again
Old Mar 1, 2002 | 04:24 AM
Inspire's Avatar
The New 3 Series Coupe
alright... fine... since i'm waiting for the answer to my question...
here... go to this site and to the diy page. you'll be able to find pic and instructions to where and how you will be able to take everything apart. take care and good luck!
http://www.autotoys.com/site.html
Old Mar 1, 2002 | 04:25 AM
Inspire's Avatar
go to the top of the page... click on tech info/links
then... go to diy series 2000/2001 and you should be able to find it.
Old Mar 1, 2002 | 04:29 AM
bebber's Avatar
I've never taken out the headunit, but there are screws that are visible once you remove the wood trim. I'd remove those first and play around with it to see what else needs to come out.
Tap into the HU speaker outputs before the EQ. You should bypass the EQ for flatter freq response if you plan on putting in aftermarket speakers. I don't know about gluing the spacers to the door. Who says you have to glue them at all? Can't you just screw the whole thing back together?
maybe someone else can give you the color code for the turn-on wire
Old Mar 1, 2002 | 05:54 PM
now i'm in deep s***, my speaker won't fix the spacer is not thick enough, i have a 1 inch spacer and infinity 93.3i, and i can seem to be take out the harness or the radio, can some one help me please, my car is apart and i need to done by this weekend.
MilanoRedDashR
Oct 8, 2015 10:30 AM
KBTypeS
25
Oct 1, 2015 04:49 PM
mshipon
2G CL Problems & Fixes
Sep 28, 2015 12:14 PM
TLguy42
Sep 26, 2015 11:27 AM
