Need advice mounting new front speakers.
Old Aug 9, 2003 | 04:21 PM
omoulton's Avatar
I am in process replacing the stock speakers and amp. I have MB Quart DSD216 for the fronts. After removing the stock 6.5'' I've run into the age old problem, the replacement 6.5" MB Quarts are not a simple plug and play.
I thought about bastardizing the plastic spacer that the stock 6.5" used but that may be more trouble than the effort. I know that some folks here have used these speakers. Any insight into a good way to mount this speakers would be greatly appreciated.
I have stopped working on this for the evening hoping I will get a brain storm but so far I've only got a headache.
Otis
Old Aug 9, 2003 | 10:08 PM
SilverKnight's Avatar
Retired. Not available.
use 3/4 MDF to make spacers and remove the OEM plastic .. should work fine.
Old Aug 10, 2003 | 10:03 AM
omoulton's Avatar
Thank you Sliverknight!!!!!!!!!!!!. Hit the Home Depot this morning and bought some 3/4" MDF per your recommendation. Made a circular spacer out off the material. It worked great. Door panel fits on, window works fine and all the controls are operational Thanks for the advice!!!
Otis
KB1_EJ6
Nov 13, 2016 09:51 PM
BKSleeper
Oct 7, 2015 10:20 AM
sockr1
Oct 1, 2015 01:31 AM
08 NBP TL
Sep 8, 2015 08:49 PM
leerbgdup
Sep 6, 2015 11:01 PM
