Navigation Problems
Old May 17, 2008 | 12:14 AM
jsrbrown's Avatar
jsrbrown
Navigation Problems
My navi is on the fritz... it won't show my location in real time and it seems to have problems with imputing addresses and giving directions. Has anyone else had this issue? and if so what was the fix? Is it in the navi unit in the dash or is it a problem with the DVD reader in the trunk? Anyone? thanks!
Old May 17, 2008 | 09:26 PM
jsrbrown's Avatar
jsrbrown
so 21 folks have looked at this and no one has any thoughts?
Old May 17, 2008 | 10:30 PM
CL6's Avatar
CL6
My only car is a Bus
did you try to reboot it?
Old May 17, 2008 | 10:35 PM
jsrbrown's Avatar
jsrbrown
Rebooting the changer in the trunk? No... what's the process for that?
Old May 18, 2008 | 02:33 PM
CL6's Avatar
CL6
Rebooting the Nav. All the other navs can be rebooted try seeing if yours can.
Old May 18, 2008 | 04:35 PM
poisx7's Avatar
try taking the disk out and inspect it.
Also then reinsert
Old May 18, 2008 | 10:46 PM
jsrbrown's Avatar
jsrbrown
I'll try it thanks
Old May 20, 2008 | 03:40 PM
slowcl-s's Avatar
Senior Airman
How do you reboot? My navigation for some reason says disk read error(consult dealer) but I've never had problems before and the disc is flawless.
Any suggestions? Thanks!
Old May 20, 2008 | 04:24 PM
CL6's Avatar
CL6
I know on the next gen tl, tsx, rl navs you could reboot it and it would go into learning mode and think it was in torrance, ca then you drive around and it learns where you are. there was a screen i used to get to that. i don't know if that's the same in these earlier models but it may be. that's my only suggestion. you'd have to search around for a calibration screen or technicians screen. on those later nav systems it was holding down like the map and some other button. been over a year since i've done it last.
Old May 21, 2008 | 01:21 PM
ljmushock's Avatar
THere is a way to get into the diagnostic screen for the nav and im sure u can reboot it from there... Im not sure how to do it tho.. i think its on a prior post tho try searching
Old Nov 27, 2009 | 10:07 AM
cleptosis's Avatar
any one know the trouble shoot protocall
Old Nov 27, 2009 | 03:42 PM
5thgen's Avatar
Trust Me I'm Better!
Turn key to II
Wait for OK to appear on Nav screen
Press OK on screen
Press Menu, Map/Guide, Cancel in this order and hold for 5 seconds
Diagnostic Menu should appear.
Old Dec 2, 2009 | 05:11 PM
cleptosis's Avatar
then wat
Old Dec 29, 2009 | 05:09 AM
cleptosis's Avatar
so no rel answear to this huh
BoricuaTL
Apr 8, 2016 01:08 PM
tallyrlx
3G RLX Audio, Bluetooth, Electronics & Navigation
Feb 26, 2016 03:44 PM
siularbar
1/2G MDX (2001-2013)
Sep 11, 2015 10:40 AM
Gianni Formica
Sep 7, 2015 08:28 PM
travr6
Sep 6, 2015 02:11 PM
