the navigation difference between 2004 and 2005
I have a 2005 TSX and i am planning for non-navi to navigation conversion. I try to find the 2005 navigation system but almost of the time i only found the 2004's. Do you guys think the 04 system should be able to work on 05 TSX?
You could try this link:
2005 TSX Center Module
I don't know what parts you need though. They all seem pretty expensive.
Thank YOu all
i don;t mind lose the compatibility with the XM. I just hope the navigation can still work.
do u guys think without the DVD unit, does the monitor and the cd player work? For those people with navigation, what happen when there is no DVD in the DVD ROM?
Is this conversion going to be a DIY endeavour ?
if so, dude you have a looong way to go.
Go luck
Originally Posted by fuckleberry
you're joking right ?
Screen displays a message saying missing media or something.
Go luck
Go luck
i found a seller for the navigation and i was asking the code for both navi and radio. but he said because the navigation computer is not included so there is no code for nav, but i will be the radio code. screen does not take any codes. is this correct?
So your "plan" is get the screen unit first and hope you find the DVD unit sometimes later right ?
just be prepared to wait...........
You input the radio code by twisting the 'tune' knob, and depressing it to enter the number. The display is up where the radio stations usually are, above the navi screen. You should get that code included with the face unit, as the radio is in there.
Puma Jim
20
Oct 20, 2016 11:59 AM
handsom-hustla
Nov 13, 2015 05:04 PM
krenaue
Sep 15, 2015 07:54 PM
Gianni Formica
Sep 7, 2015 08:28 PM
I think you'll lose the compatibility with the XM display. Other than that, the two are basically identical.
