Navi-tuner problem
9th Gear
Navi-tuner problem
I have the AVElectronic navi tv tuner installed in my 03 CLS. It works great the tv and the dvd but when I turn on the system I usually have it on Line 1 which is my tv and line 3 is my DVD. But when I first initially turn it on it turns into a blue screen so I have to push the input button and go through all of the lines until I get back to line one so I can watch the TV. I figured when I turned it on it would just directly go to my TV. It will show the tv singal for a brief second and then go to a blank blue screen until I go thru the lines and then back to Line 1. It does the same thing for my dvd line 3. I think everything is installed correctly because the tv and dvd work fine. But if I'm on line 3(dvd) when I start up my car and then go to line 1 it will play my tv fine. Any help will be GREAT!! Hope all of this makes sense.
9th Gear
I put my antenas along the edge of my back side windows. It actually looks pretty good and my windows are tinted so you can't see them at all from the outside. I just ran the wire underneath the panels into the trunk so I don't have any wires showing.
SidhuSaaB
05-30-2020 12:40 AM
Fool
03-10-2016 08:42 PM
