Navi question
Old Mar 29, 2001 | 12:04 AM
Guest
Guest
Posts: n/a
Post Navi question
Just got my new TL-S w/navi. Is it possible to shut it down after you have pressed menu or map guide without cutting ignition? Sometimes I have the map guide on or I have input a destination but later want just the big clock or blank screen.
Old Mar 29, 2001 | 03:15 AM
Nate's Avatar
Post
Put it in screen saver mode. Don't ask me how, I don't have navi.
Old Mar 29, 2001 | 08:34 AM
Guest
Guest
Posts: n/a
Post
Thanks, Nate, I think I'll install 3-D Pipes, I like that one. Does anyone else have an intelligent thought?
Old Mar 29, 2001 | 08:36 AM
FTM-1's Avatar
Post
Yes go to the small setup box at the bottom of the screen. When you press it the setup screen will come up this will have the controls for volume,brightness,etc. Also it will have a buttom to turn it OFF. The clock can also be made larger if you don't want the map screen ON. Also the clock can be made larger to the screen if you just push the small clock numbers then they come up larger to the screen.
2000 3.2TL Nighthawk Black/Ebony/Navigation/ Optional Factory Chrome Multi Spoke 16" Wheels/Factory Underbody Kit/Factory Spoiler/Moonroof Visor/Factory 6-CD Changer/Trunk Mat/Factory Black Wheel Well Trim/Clifford IG8000 Alarm System w/add-ons/%51 Tint/Weathertech Floormats /Michelin Arcctic Alpin Winter Tires on Stock Wheels/Factory Car Cover/Factory Gold Emblems Grille & Exhaust Tips
<FONT COLOR="#800080" SIZE="1" FACE="Verdana, Arial">[This message has been edited by FTM-1 on March 29, 2001 @ ]</font>
Old Mar 29, 2001 | 01:45 PM
Guest
Guest
Posts: n/a
Post
FTM-1, thank you for fulfilling a primary purpose of this board. Much appreciated.
Old Mar 29, 2001 | 11:49 PM
FTM-1's Avatar
Post
I can return this favor to you guys because someone helped me when I got my car.When I got my car my 10yr old nephew was pushing buttons on the Nav & had all the icons come on the screen. I did not no how to get them off someone helped me. My nephew was also pushing the buttons & made the clock come up larger. I said how did you do that & he told me push the little clock. So you can get the clock larger with the map screen off by this way or going to the set-up screen.
06TLMatt
Oct 2, 2015 08:14 PM
truonghthe
Oct 1, 2015 03:13 AM
datadr
Sep 12, 2015 09:12 PM
Vejey Gandier
Sep 12, 2015 08:59 PM
Gianni Formica
Sep 7, 2015 08:28 PM
