Navi Conversion w/ Sirius Satellite...
Old Jan 12, 2005 | 02:42 PM
KissMy_Type_S's Avatar
I already did the navi conversion and now i would really like to add a Sirius receiver. Can I just add "Y" adapter RCAs to my Blitzsafe and hook up the receiver to that (The Blitzsafe is currently hooked up directly to my PS2). Or what other options do I have? I really dont wanna use an RF Mod cuz a) the wires look messy and b) the sound is never as good. Any other suggestions?
Old Jan 14, 2005 | 06:21 AM
no one?
Old Jan 15, 2005 | 08:46 PM
withoutcomp1's Avatar
No, You would have to get a A B Switch Made from two relays. I can do it for you if you want let me know i work at a shop in Brooklyn. Or I can make one and send it to you.They will feed into each other and cause a problem if you just y-jack it.
Old Jan 17, 2005 | 06:45 AM
really? ok thats the info I was hoping to hear before I went ahead and did it, thanks a lot. What else would be involved besides the relays? And if you could briefly explain the switch set up. It would be something that I could mount a couple of feet (in wire length) away? Im in Nassau County so goin to Bklyn on a weekend is no problem. I work in Manhattan so if your open later I could swing by after work too. Let me know also how much $$. Thanks again.
Old Jan 17, 2005 | 07:48 AM
Open till like 7 30- 8. About 40 bucks Friday i will be there later doing some work to my car. It will just be a regular toggle switch, you could mount it wherever you want.
Old Jan 17, 2005 | 11:00 AM
Jonesi's Avatar
They are a little larger but if you go to radio shack just pick up a A/B switch..
Old Jan 17, 2005 | 11:57 AM
Yea i considered it, but now since withoutcomp has already gone through this and developed something that will work for this application then might as well play it safe and not burden myself with another project. Good lookin out all thanks for the insight.
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
blacktsxwagon
Oct 27, 2015 10:12 PM
lanechanger
Oct 13, 2015 10:56 AM
jmaxima03
Sep 27, 2015 10:22 AM
Cgannotti
Sep 25, 2015 05:04 PM
