Nav to DVD in TSX (Can ANYONE Make This Simple??)
I spent the last 2 hours looking at posts and trying to understand how to convert the nav screen to play dvd's and watch tv and i got nowhere!! Is there ANYONE who can make this process simple?!
What products do I need to make this work??
How much will this all cost (A Roundabout $$ would be amazing)
Are there any detailed directions out there???
and finally...
Is there anyone in Central NJ who knows how to do this and has some time on their hands??
and finally...
Originally Posted by twanugolden
I spent the last 2 hours looking at posts ... nmd got nowhere!!
Some need to be hardwired in. (I use a NavTV that needs this... I don't know about Domofnavwithtv's unit.)
Some are "plug-and-play with no cutting. (Vsokolov's works like that)
Some also include a tuner (AV Electronics, which is also plug and play in installation but has a TV tuner I don't recommend.)
stop "researching"/ asking and waste your precious time if you can spring about $700 to $800 = DVD player+ TV antenna+"Conversion Modules"+FM Mudulator+INSTALL
2 vendors : vsokolov and domofnavwithtv
They both have shops in Brooklyn, so head east....
Its very very simple! If you buy DOMS UNIT you need to cut 4 wires. I used the wires from a plug behind the passenger side kick panel. I also mounted the unit behind the passenger side kick panel. Once you cut those 4 wires you need to connect the unit to power and ground. Once that is done, simply plug your video source (dvd player, tv tuner, etc) in to the unit. It comes with a switch that allows you to toggle back and forth from your stock Navi/accessory screen to your video source. You can also hook up a seperate video source to the unit like a back up camera that turns on when you put your car in reverse.
The unit only convertes VIDEO. Once you get it connected you need to figure out how to get the Audio to play. This is a totally seperate beast!
cycdaniel
12-17-2019 10:58 AM
Rocktman1
09-19-2015 05:58 PM
andysinnh
09-05-2015 11:38 PM
