My amp keeps shutting off?
Old Jul 23, 2004 | 03:08 PM
Rod's Avatar
Rod
I have had a 12W3v2 and JL 250.1 installed for the past couple months with no problems, but yesterday the amp started shutting off intermittently for no apparent reason. It'll come on for a while and then turn off for a while, sometimes lasting a couple minutes and sometimes just seconds with no pattern to it. What do you guys think can be causing this? It's not going into protection mode because the red LED doesn't light up, the only thing that happens is that the green power LED comes off and on with the amp. I checked the connections and none of them seemed to be loose.
I really don't know much about this type of stuff so any help is greatly appreciated. I will most likely be going back to the installer tomorrow morning but don't want to go empty handed, I'd like to have some ideas. I'm thinking it could be a bad ground, but wouldn't this have shown up sooner instead after all this time?
Thanks for your input.
Old Jul 23, 2004 | 03:25 PM
N.O.6speed's Avatar
WESTK
check your ground wire connection at the amp and on the chassis, or whatever they grounded to.
That is probably your problem.
Old Jul 23, 2004 | 04:17 PM
RBARNES24's Avatar
THIS SOMETIMES HAPPENS TO ME. i HAVE AN AFTERMARKET SYSTEM INSTALLED PERFECTLY CORRECT, 4 GAUGE ALL THE WAY. OCCASIONALLY IF I CRANK THE VOLUME TO HARD, EVEN THOUGH THE MIDS AND LOWS CAN SUPPORT IT, MY SUB AMP WILL SHUT OFF, THEN TURN BACK ON, ONLY WHEN THE BASS TENDS TO HIT THE HARDEST. THIS IS BECAUSE, I HAVE BEEN TOLD, I AM ASKING FOR TOO MUCH POWER FROM MY BATTERY AND ALTERNATOR. THE SUGGESTION WAS GIVEN TO START WITH EITHER ADDING A CAP TO THE SUB SETUP, GETTING A STRONGER ALTERNATOR, OR GETTING A SECOND BATTERY (I.E. OPTIMA) FOR THE STEREO ALONE. HOPE THIS HELPS???
Old Jul 23, 2004 | 05:51 PM
proaudio22's Avatar
-S namyaC-
^^no, it's your amp going into protection b/c either the input is too high or the impedence of the subs is too low.
Old Jul 23, 2004 | 07:31 PM
UNCTYPE-S's Avatar
Above n Beyond
99% of the time its your ground, make sure it is locked down and secure, or reground it somewhere else.
Old Jul 24, 2004 | 10:48 AM
Hobo's Avatar
Flap.
take the dildo off your caps lock button
Old Jul 24, 2004 | 05:14 PM
Rod's Avatar
Rod
Thanks for the replies, but it was a very simple fix, it was just the fuse. I feel stupid now. The thing is it didn't look blown when I checked it through the casing, but when I took it out of the casing one of end caps on the fuse was corroded so a new fuse fixed the problem.
Jul 16, 2017 07:33 AM
copmagnet82
4G TL Problems & Fixes
Jun 29, 2016 08:09 AM
InFaMouSLink
Oct 30, 2015 09:43 AM
prbori
Sep 27, 2015 01:37 AM
