Making a Sub box
USMC Butterbars
Making a Sub box
Well I got a quote from a shop and they wanted $200 to make a box. I said fock that. So I decided to make the box myself. However, I do not have the first clue as to what needs to be done. I took some measurements and what not and I have come up with the following:
LxDxH = 20" x 12" x 13"
I plan on using 5/8" Medium Density Fiberboard. So the total interior volume comes out to 2368.36cu in. (hope i did the math right) I will cut out a hole for a 10" sub on one face. I will drill nails in every 4 inches along with sealant in the interior of the box.
What do you guys think? Is that enough/too much volume for a sealed box? I plan on mounting a single amp(speaker amp) on the back side of the box and another amp(mono amp for the sub) on top of the box. This will help with the limited space I have to work with. The sub will be facing the back of the car.
Boomer SOONER
Originally Posted by UnsanePyro
Hmm, don't subs usually have a recomendation as to the size of the box in cubic space? I would go with that...
exactly, each sub will have their own specific box requirements. What kind was it?
for example, this is the sheet for my sub...JL 12W3V2 specs
$200 doesn't sound bad at all to me!! Here in cali, I can't find a place to make a custom box for under $300. If you think about it, at least $80 in wood/screws/opoxy/ect. Then at least 2-3 hours to make the box. If they wanted $60/hr thats $120-180. There's your 2 bills!! Small price to pay to get a custom box done by professionals with the perfect specs for your setup.
FYI, I did my own box for my gs400 a couple years back and it came out decent. I went to kicker.com and found the wiring diagram and correct box measurements for my 12" L7. Cost me about $100 all said and done but it wasn't perfect... I will have someone build one for my TL in the future...
Anyways... GOOD LUCK!!
cycdaniel
12-17-2019 10:58 AM
alan_rich
09-09-2015 11:38 AM
