Looking to do a 2.5" screen in a TL mirror.....
Anyone want to be the first? I will offer a pretty significant discount to the first person....we normally charge $950 including the monitor, and it will look like this (this is one I just finished for a customer in his BMW):
It's made by accele....same one we have in the BMW, and the same one pictured above. I believe the TL has a set screw that needs to be loosened, and then the mirror slides UP and off. Not exactly sure, but I will check mine when I get home.
The process is reversible, but you would just have to have a new piece of glass cut. We DO NOT cut the tv into the glass, it is physically BEHIND the glass, and the reflective parts are removed where the monitor is mounted.
incredible work again ron...i had a question i have a set of monitors i wanted to use for my visors....but the input kind confuses me there is not rca or s video just a bunch of wires...in my case...6 wires for the video source.......how does that work the screens are made by sharp.....their 6.8 inch...does it need a converter or anything....or does it use rgb signal or a composite signal...what are the screen usually using?
thanks
thanks
their fairly new i bought them from a guy from the bmw forums....he said they are working and from the looks of it it is in perfect condition.....these are the screens that are just the monitors with no frame...i wanted to put them in the visor they are abour 3/4 of an inch think...do you think they will fit? how think can a screen be to put in the visor? i will try to get a pic up asap...
SEND THEM TO STREETEFFECTZ!
Isn't that screen supposed to be used as a screen when you reverse. Cause i forgot where i seen that mirror before. And somewhere on http://value-caraudio.com/Merchant2/...y_Code=INPARTS they sell the spoiler with the camera on the back so you can connect both.
