TL: LOC or not?
LOC or not?
I have looked over this thread multiple times and still cannot figure this out....
https://acurazine.com/forums/audio-video-electronics-navigation-22/need-help-advice-anything-adding-sub-185395/
Do we need a line out converter or can we just use one of these?
http://www.dealercostcaraudio.com/jl...lraic2-sw.aspx
Currently our Amp is getting power so it must be a signal problem
Here is where we are right now.
[IMG][/IMG]
Can someone confirm that these are in fact the signal wire for the factory amp?
[IMG][/IMG]
Thanks!
[IMG][/IMG]
[IMG][/IMG]
Thanks!
whoah...are you trying to add an amp and signal for a real sub?
if so...why are you messing with the oem amp. Run a separate remote turn on from a fuse under the dash. Much easier. BUT, that said, I THINK I recall the orange wire being remote turn on. Check with a circuit test...radio off, radio on.
As far as LOC goes...just wire that into the stock sub - and + wires, remove stock sub and connect your rca's to your amp from the LOC.
I used the remote turn on wire that activates the factory amp. Okay so use speaker wire coming out of the factory amp? I thought it was a no no to fetch a signal from a wire that has already been amplified?? I guess that is what the LOC is for.
alan_rich
09-07-2015 11:08 PM
