TL: Loc help
Loc help
i have the schoosh slc4 and cant get it to work after following the DIY can anyone help me does it got after the factory amp im just frusterated and lost
tapping in to the rear door speakers in the b pillar
any ideas and taped the wires in to the in put and had the switch to line out and had the rca's plugged in to the the rear output
it was working but it was using the sub as a speaker not a woofer
Stock sub is amped yes? That means there's a lot more signal flowing through those wires... Your normal everyday loc won't handle that high signal, and will die on you in a fairly short time... There was another guy that had that problem on here a couple months ago or so. So, just a heads up, don't wire off the sub and come back complaining you weren't warned...
alan_rich
09-07-2015 11:08 PM
