Lines on Screen
Old May 27, 2005 | 10:23 PM
Lines on Screen
After installing the Navi to DVD converter I am getting lines on my screen when the engine is on... is it possible to do something about that?
Thanks.
Old May 27, 2005 | 11:01 PM
Akim711's Avatar
dynamic Duo!
its a common problem that everyone's still looking collectively for a solution. Our best guess is that its a grounding issue.... Also perhaps bad shielding of the signal wires. a 12 volt voltage regulator for the power input would also help... but i don't think anyones really tried any of this out yet to see if it works.
Old May 27, 2005 | 11:14 PM
elduderino's Avatar
VP Electricity
Actually, the lines on the screen with the car running are a standard characteristic of poor power wire filtering on video gear. An outboard filter works and there are confirming posts in the AV section... as you should remember, akim, you commented on it..
https://acurazine.com/forums/showpos...2&postcount=68
MrHeeltoe
20
Feb 23, 2023 01:54 PM
SidhuSaaB
May 30, 2020 12:40 AM
copmagnet82
4G TL Problems & Fixes
Jun 29, 2016 08:09 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
