Line out Converter through front speakers?
Old Feb 1, 2008 | 05:38 PM
tmcao55's Avatar
I added a sub and amp to my TSX using a line out converter tapped through the rear 6X9's. The problem is that the rear 6X9's play a 50hz peak, the signal is not linear. It sounded like ass. Really boomy.
Has anyone noticed this when running a line out converter through the rear 6X9's?
Has anyone ran a line out converter through the front door speakers? The frequency response is alot more linear. Would running the lineout converter through the front speaker signals theoretically sound better?
Old Feb 1, 2008 | 10:47 PM
Reach's Avatar
Yes, much, much better. However, you might just want to grab the whole signal from the stock amp and pipe that to your sub amp if you want to go all the way.
Old Feb 2, 2008 | 03:49 PM
feuss2's Avatar
10001110101
I switch my LOC from the rear 6x9's to the rear door speakers (for the same reason) and there is a very noticeable improvement in sound quality...
Old Feb 2, 2008 | 05:40 PM
tmcao55's Avatar
I figured it would sound much better through the front speakers. Thanks.
Old Feb 2, 2008 | 06:40 PM
madmanmax3000's Avatar
Professional Newbie
keep in mind front drivers side is very difficult to get to, do passenger's side or just do it right and pick up one of mercman's harnesses
Old Feb 2, 2008 | 06:43 PM
Reach's Avatar
front / rear is going to be the same signal.
Old Feb 2, 2008 | 07:06 PM
tmcao55's Avatar
I plan on getting the signal from the wires at the amp.
Old Feb 2, 2008 | 07:08 PM
tmcao55's Avatar
Are you sure? I was looking at this
http://picasaweb.google.com/castles....16270485210226
The rear signal doesnt seem to be as linear as the front.
Old Feb 3, 2008 | 09:19 AM
Reach's Avatar
Guess you're right... I'm posting Castles Saloon's plot for reference.
Old Feb 3, 2008 | 11:33 AM
mercman's Avatar
This is why you should ditch the factory amp, even a small 40 watt/ch unit would be an improvement over stock. I can tell you that the stock HU is flat so you will get a full signal to your sub and other channels. Then you can Eq or adjust the HP/LP filters to your liking.
Jeff
Old Feb 3, 2008 | 07:18 PM
tmcao55's Avatar
Jeff
If i was amping the whole sysem i would do what you reccomended. Im only planning on adding a sub. Is there a better way of doing it? Are you talking about getting a signal from the 14 pin connector at the amp instead of tapping the speaker wires??
Old Feb 5, 2008 | 05:13 AM
feuss2's Avatar
10001110101
Jl 500/5!!!!
Feb 25, 2020 09:57 AM
sockr1
Oct 1, 2015 01:31 AM
08 NBP TL
Sep 8, 2015 08:49 PM
alan_rich
Sep 7, 2015 11:08 PM
