Line Converter Ques.
Old Feb 27, 2007 | 02:32 PM
CLean's Avatar
Cars are an addiction
I have a Kenwood KCS-SW1 powered sub for my truck.
Now, since I have the stock single CD headunit in my 04 F-150 SCAB, what would be the best way to install it. The unit has RCA preamp and speaker-level inputs.
Would it be be better to tap right off the rear speakers using and go into the speaker level inputs or get a line converter and run RCA's to it.
Or would it make no difference.
Here is the specs on the unit http://www.crutchfield.com/S-e5Ot6tg...sp?i=113KSCSW1
Thanks...,.,
Old Feb 27, 2007 | 02:56 PM
fuzzy02CLS's Avatar
"Would it be be better to tap right off the rear speakers using and go into the speaker level inputs"
I would do this. It's easier & you won't have to deal with a turn on lead. My basslink is connected this way. Run power to the battery run a ground to somewhere in the back & your done.
Old Feb 27, 2007 | 03:25 PM
CLean's Avatar
Understood as far as the power. Dont I need to hook up the remote switch?
And I assume by quoting me, you would just tap off the speakers and use the speaker level inputs? And not get a RCA converter. Am I correct or did I miss something..
Old Feb 28, 2007 | 07:54 AM
fuzzy02CLS's Avatar
If you use the speaker inputs, the sub will use it's own auto turn on/off. You only need a remote turn on lead if your using the RCA jacks.
Old Feb 28, 2007 | 08:32 AM
CLean's Avatar
Ohh. Great.. Maybe I should read the directions.... Thanks for the info..!
MrHeeltoe
20
Feb 23, 2023 01:54 PM
copmagnet82
4G TL Problems & Fixes
Jun 29, 2016 08:09 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
Dman00tl
2G TL Photograph Gallery
Sep 25, 2015 10:34 AM
