CL: Large 6x9 speaker touching trunk support bars
Old Aug 15, 2009 | 02:22 PM
martin_t's Avatar
8th Gear
Smile Large 6x9 speaker touching trunk support bars
Hello,
I just installed new Infinity Kappa 6x9 on the rear and man these speakers are large (to me that). They are so large that they touch the bars that connect to the trunk ( i think the bars are for trunk support). Well, I left the speakers as is so when I lift the trunk, the bars touches the speakers making it shift upwards. I wondering if anyone had this problem and had a fix for it. Can I remove the trunk support bars? Are there mods for it?
Thanks in advance.
2001 Acura CL-S
Old Aug 15, 2009 | 02:49 PM
mattastick's Avatar
You can spacer out the speakers. You can run anything from a thin piece of ABS (as thins as 1/4") up to a 3/4" piece of MDF.
Old Aug 17, 2009 | 08:22 AM
martin_t's Avatar
8th Gear
My concern is will the rear panel that covers the speakers fit after the spacers are installed?
Old Aug 17, 2009 | 01:42 PM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
How much clerance do you need? I have plastic spacers that I made when I had to go to 3/4" mdf. PM me if you want info on the spacers
Old Aug 17, 2009 | 07:01 PM
martin_t's Avatar
8th Gear
Ideally I would like enough to when I open the trunk, the support bars will not touch/lift the speakers. Yes, please send me specs (pictures if you can) on your spacers. I'm thinking 3/4" will create enough clearance between the bottom of the speaker and trunk support bars.
Thanks!
Old Aug 18, 2009 | 12:31 PM
(Mid-Atlantic)
I will dig mine out, I think they're only 1/2" but I really don't need them so if you're willing to try them I'll let them go dirt cheap. I'll try to remember to dig them out today
Old Aug 18, 2009 | 06:33 PM
martin_t's Avatar
8th Gear
Let me see how much clearance I have without creating issues with the back panel.
Old Aug 18, 2009 | 10:53 PM
martin_t's Avatar
8th Gear
After a closer look, because the trunk support bars bends near the speaker, when the trunk lifts, that bend also moves upwards about 1". Now if I install 1" spacer, I'm afraid the rear deck panel will not insert all the way. Do I really need the support bars? Are they use to slightly lift the trunk when the trunk release button is press? Can I possibly remove the bars all together? I hate to get rid of these speakers because they sound excellent.
Old Aug 19, 2009 | 11:26 AM
richardparker's Avatar
3.7L Nitrous Breathing CL
The bars can be removed,but they help hold the trunk open.If you dont mind it droping on your head or back when you take your hands off.A couple of people went to struts insted of the bars,but they can be a PIA to get them right.
Old Aug 19, 2009 | 03:37 PM
(Mid-Atlantic)
They help open the trunk, and keep it from slamming down on your head, I made 3/4" spacers for mine out of mdf
SidhuSaaB
May 30, 2020 12:40 AM
Brandle34
Sep 23, 2015 07:20 PM
justin.w13.walker
Sep 22, 2015 02:21 PM
ExcelerateRep
Sponsored Sales & Group Buys
Sep 22, 2015 10:39 AM
