TL: JL sub
Old Oct 14, 2010 | 08:19 AM
xunruli's Avatar
5th Gear
JL sub
Hi, i'm new here. Just wondering is $200 for the JL 12W6V2 sub a good deal? Just the sub alone, no amp.
Thanks,
Long
Old Oct 14, 2010 | 08:59 AM
fourthmeal's Avatar
They run $300-500 new, so sure if you are set on buying that model. But if you are asking if buying this sub is worth $200... I submit that better subs cost about the same or less.
Old Oct 14, 2010 | 02:13 PM
eggyhustles's Avatar
Great sub for 200.
Old Oct 14, 2010 | 04:39 PM
dykyy's Avatar
Yes 200 is quite worth it.
Old Oct 14, 2010 | 10:05 PM
Jimmay's Avatar
For 200 it is for that sub...but im with fourthmeal. You can find something better for the price.
Old Oct 15, 2010 | 01:43 PM
vega487's Avatar
7th Gear
When it comes to JL the box has a lot to do with it. The W6 I a really good sub. But don't skimp on the box. That sub has a lot of potential as long as it is done right. Hope is all goes well.
Old Oct 16, 2010 | 07:29 PM
xunruli's Avatar
5th Gear
Guys, thanks for all the responses. So i went ahead and got the sub&amp for my 02 TL. I read the sticky on how to install the sub and amp. I went ahead and removed the rear seat (top and bottom section), but I couldn't find the stock amp. What does it look like guys? and where is it located after I take the seat out.
Old Oct 16, 2010 | 08:51 PM
fourthmeal's Avatar
I left the stock amp in place, I'd recommend the same. Just remove the stock sub, disconnect, and you're good to go.
