JL audio 6" subs
JL audio 6" subs
hi, for those of you w/ the tsx already. (mine is on order) wht do you think about replacing the 6x9 rear speakers w/ some JL 6" subs? they ar 6.5 inches actually, do you think they will fit where the 6x9 goes ? or do i need to do some mods? and wht do you think about the sound?
Registered AssHat
I wouldn't classify a 6.6" speaker as a "sub". In fact the door speakers are full range 6.5"s. I don't see as you you gain anything. If you go subs, at least do 8".
yea but i didnt want to add a box or anything. im just asking some questions as some ppl on audio forums told me i might want to look at some 6.5 or 6x9 subs rathering then getting some 6x9 speakers.
Registered AssHat
Well the 6x9's that are back there are one-way subs as it is. SInce the dorr speakers are already 6.5" full range, you get all your bass through them. The back deck is getting all the low frequencies. I would stick with 6x9's or go with a 8" free-air sub in place of the 6x9's (make a custom attachment). Obviously the 8" subs would need a separate amp.
Easiest way to upgrade is to replace the 6x9's in the back with something that has better bass response (ignore the other frequencies).
However, most people on this board have heard the best increase in sound quality by replaceing the 6.5" door speakers with Polks or Inifity 2- or 3-ways. One persopn even replaced theirs with Alpine's, but it needed a very custom install (too much speaker depth on the front doors).
it wont work to replace the 6x9's with subs,
1. the JL sub requires a box, they arent infinite baffel speakers
2. you will need more power than the stock amp has on tap to power them
3. you have about 1/2 the cone area as a 6x9 and therefore it will have less bass than stock.
The reason I picked them is because they go down as low as 25Hz (which is actually lower than some 6" woofers), and they have a decent sensitivity rating of 92dB.
All in all, it was a cheap and easy way of cleaning up the bass... it's not "boomy" at the moment, but it is tight and much cleaner than before. Totally worth it if you don't want to go the "amp and sub" route.
If anyone likes, I will post pics of the installed speakers. Thanks.
Bite my shiney metal ass.
Originally posted by dave2music
I went the easy route and (after extensive research) bought a pair of JBL 6x9's (I'll have to get the model number and post it later). They are 3-ways, but of course, being replacements for the stock 6x9's, they only receive the low frequencies, which is fine.
well i found some 6x9 subs and i think that is a better option after doing some research. basically the tsx has 2 sets of 6.5 full range speakers already so therefore i think its impractical to get another full/mid pair of speakers. however, if you intend to add some subs then a full/mid pair of 6x9 is ok. im doing some research on car audio now as i want to upgrade my stock system when i get my tsx, which arrives in about 2 weeks.
Originally posted by A4NoMore
Was it an easy out-and-in install?
As a side note, I also replaced all the door speakers, and it was the BEST investment I think I've ever made.... the stock speakers are really cheap, and replacements make a HUGE world of difference! Again, if anyone is interested, I have pics also.
Thanks...
make sure you buy speakers wiuth high sensitivity rating, this will ensure max db with stock amp.
i am replacing all stock speakers as well as getting a new amp. Ive posted on many forums and did some research. the tsx already having 2 sets of full way 6.5 will not benefit much from having a mid/full 6x9 in the rear. im getting 6x9 subs b/c i dont want to add a box.
I keep saying that I will post pics and I promise everyone I will...sorry for the delay!
dave2music
I wound up putting JBL GTO635 6.5" in all four door speaker locations, and some great 6x9's in the back. dave2music
Originally posted by jlukja
Dave2, What model 6x9 JBL did you put in the back?
http://hypaudio.com/hypaudio/p9632.html
They sound great, and putting them in one super easy, and they just barely clear those bars in the trunk. Let me know if you have any questions!
Thanks,
I've also been toying with the idea of replacing the speakers. I've seen the threads (with pics) on how to do it and other threads on which speakers people liked. Seems like Infinity, JBL, Alpine, and Polk are the brands of choice for the doors and I've been looking for some recommendations for the rear 6x9s.
One other question, is it important to match speaker sensitivity between the door and back speakers? (i.e. 92 db in the doors would call for 92 db in the back). And if you don't match the sensitivity is it something you can overcome by adjusting the bass level on the head unit?
Thanks,
Thanks,
As far as speaker sensitivity, a basic explanation is that it is a rating on how loud the speakers will play at the same volume. So a speaker rated at 92db will play louder than a speaker at 90dB when the volume knob is in the same position. It won't be a huge difference when you find ratings close together that are off by maybe 1 or 2 db...shouldn't be anything to worry about, especially since the 6x9's are only driving bass frequencies...you call always tweak it a little with the bass control off the head unit. The door speakers should probably be all the same, since some brands and models can have quite a difference in sound quality.
Some 6x9's I found were quite good were:
JBL P9632 25Hz-25KHz 92dB Sensitivity
Alpine SPS-690A 30Hz-30KHz 92dB Sensitivity
Pioneer TS-A6990R 25Hz-32KHz 93dB Sensitivity
Pioneer TS-A6960R 28Hz-28KHz 93dB Sensitivity
You really only need to pay attention to the low frequency range, and the sensitivity rating.
Anyways, hope that helps, and sorry if I rambled on too much!
I would not get some full/mids for the 6x9 in the rear. Ive done some research and its NO good. for the 6x9 get some TB woofers. they r 35 bux each and are excellent speakers.
here is an excellent article on how a GOOD sound system is suppose to be. Replacing all stock speakers simply will not give u a better system. you dont have to spend as much as you think. just do a lil research!
http://www.betteraudio.com/geolemon/Phasing/Phasing.htm
as for speakers there are many good ones. personally I wouldnt get polks,jbl, apline etc....
good speakers :
CDT cl-61 -150 dollars
DEI Viper 650.2 - 140
good speakers :
good speakers :
good speakers :
Thanks for all the info and feedback from everyone...i keep repeating it, but pics are on the way.
dave2music
Bound for Europe
The model number is JBL P9632. Here is one website I found with a picture of them and the specs:
As a bass player, I find the bass to be way BOOMY when I crank it up. As someone who would hate having to do anything more than simply replacing the stock 6x9s with aftermarket goods, you're actions have moved me to take action as well. Thanks for the detailed info.
Originally posted by Soze75
I just realised you're in Vancouver.
Where'd you get them JBLs?
I don't know if the forums mod would want me posting where I bought the stuff (heh heh... no advertising!), so please feel free to email me at dave2music@yahoo.com and I would be happy to let you know... that goes for anyone else out there also who may have more questions! Thanks for all the feedback!
dave2music
Don't listen to me.
I started out tring Alpine SPS-690A 6x9
• Peak Power 250W
• 50W RMS Power
• Spoke Design Grill System
• Frequency Response: 30Hz – 30kHz
• Strontium Ferrite Woofer Magnet
• Aluminum-Coated Woofer Cone
• Rubber Surround
• Nomex® Spider
• Balanced Dome Tweeter
• 2-1/4" Pulp Cone Mid-Range
They Sucked
The stock system does not have the power to use any other decent 6x9. The door speakers are a diffrent story that is well worth the time and money. As for the Subs if you don't want to put a box leave them alone because the difference won't be worth the money.
• Peak Power 250W
• 50W RMS Power
• Rubber Surround
• Nomex® Spider
They Sucked
• Peak Power 250W
• 50W RMS Power
• Rubber Surround
• Nomex® Spider
They Sucked
• Peak Power 250W
• 50W RMS Power
• Rubber Surround
• Nomex® Spider
They Sucked
That's where the sensitivity specification will make a difference. Do you happen to know what it is on the Alpine's? you'd want it to be as high as possible. Of course, 6x9's are never gonna vibrate the trunk lid off your car like a good ol powered 12" sub! Heh heh! Did you try any other 6x9's?
dave2music
Don't listen to me.
Yeah... I checked out so many 6x9's..unfortunately to say, the clarions sucked also... I love clarion, but they were no good...
dave2music
dave2music
My bolonga has a 1st name
1 Post
i so want to do this... problem is i like my stereo to be loud... i like the output of the stock speakers in terms of volume... i drive with my windows down alot (live in fL) and my stereo is normally at 35 or so and i'm loving the loudness... but I' dont like the quality... do you think replacing the speakers alone would solve this problem and still have it sound just as loud? (or at least as loud as the 35 on stock speakers?) Bottom line is i dont need it to be louder... i just need it to be JUST AS LOUD as stock... but clearer... and better sounding.... would u recommend going the route of just replacing the stock speakers for my needs?
PS i'm planning on Disconnecting and getting rid of the 6x9s all together... beacuase I've already got 1 alpine type R 12" sub that i'm going to put in the trunk. So i'm really considering just replacing all of the door speakers.
you need an aftermarket amp. also go with some cdt components. best bang for the buck. i had some diamond s600 hex components in my last car, and to be honest i prefer my cdts now. the midbass on that unit is pretty weak. focal is just too damn $. no need to even look at rainbow
well if you are looking for loudness then you could replace all the speakers. but if you are looking for SQ then ditch the rear 6.5 and 6x9. get a badass frontstage and some subs in the back.
Don't listen to me.
However if you plan on putting the Alpine type-R speaker in the trunk, the stock amp will not produce much sound. That is too much speaker for the stock amp. You will need a mono amp for that speaker.
1 Post
If you don't need it any louder then replacing the speakers will do wonders. It may even get a little louder.
1 Post
so do i need a component set for the front? or do you think I could get away with just some replacement speakers for the front and rear doors? i'm gonna be looking for 6.5s right? I'm on a tight tight budget; i'd LIKE to not spend more than 200-250 on both pairs.
you could get:
cdt cl-61 from the zeb for 150
or
DEI Viper 650.2 for 140 at sound domain.
Don't listen to me.
Remember that you will have to modify the door brakets because the monting dept is very minimal (less than 2 inches). You can buy just about any speakers but don't go crazzy. (ie. alpine type-x)
Infinity REF6002SI 6-1/2" Two-way shallow mount would be perfect.
1 Post
You can ger away with just some replacement speakers for the front and rear doors. Yes they are 6.5.
You can power your sub and front stage with a 3 or 4-channel amp, you don't need 2 amps.
Depending on what sub and front stage you get (based on your budget), have a look at Audison SRx3 which should be powerful enough, not to mention it is not that expensive.
Link: http://www.audison.it/prodotti.asp?l...&idprodotto=49
You can have it output 2x65wrms to the front stage (4 ohm) and 1x340wrms for the sub (2 ohm).
navtool.com
31
11-16-2015 08:30 PM
InFaMouSLink
10-30-2015 09:43 AM
