JL 10w7 question
JL 10w7 question
how many decibals when getting metered should this sub be putting out???
just 1 10w7 with JL 500.1 amp with my stock headunit bass knob and my JL bass knob turned all da way up??
thanks
mike
i dont think i did to good but ill post wut i metered afta wut ppl think it should be at..
BTW i was using Freak a leak as my weapon of choice today in da sound off lol.
thanks
mike
wow!!! i only hit 125.. can it be my amp settings? since i did mess dat up big time... also i didnt dynamat my trunk yet would dat help my dB?? i was shocked.. atleast my 1 10w7 hit harder than sum guys 2 10w7s wit 1 amp for each.. lol
Originally posted by Nicky Pass
Look at the setting in the book that you got with the sub....thats how mine is set!
Flap.
adjusting the gain on the amp will change everything... im not familiar with all of JL's settings, but the xovers, gain, boost, and ohms (cause its jl) all need to be set correctly to maximize performance.
Flap.
^not the correct way to set the gain
turn the gain all teh way down....
turn the source unit to 2/3 vol
adjust gain to comfortable listening level.
bass boost adjustments should be made to compensate for areas of less spl or volume... the freq of the boost depends on woofer size, box type, enviroment, and music listened to.
Who built the enclosure? I've seen many people say they built the box to spec and it didn't sound great. If you see the JL built 10W7 H.O. box its much larger than what they recommend in the owners manual. The JL built H.O. box is great.
navtool.com
31
11-16-2015 08:30 PM
DerrickW
11-15-2015 05:52 PM
