TL: Installing HID fogs into low beam???
Ok i have a question...I bought a HID Xenon FOG 4300k Conversion for my TL...It works fine everything is good...
But have anyone tried to put it onto the low beam part?...would the wiring fit perfect??..would it work??..or is it just made for the FOG light and not the LOW beam??
Ok am I missing something or do you want to put the fog lights in your low beams? You have factory HIDs so I'm really confused now, do you mean the high beams?
Regardless, your HID kit should be fine wired into either lows or fogs. The ballasts and wiring should all be the same no matter what bulb base they retrofitted on the D2R. Obviously, the bulb wouldn't be a direct fit tho
Lemme recap...I got HID kit for my FOG Lights..but when i wire them up to my low beam they wont fire up...
is there a way to make it work??..yes i know both bulb is the same i tried switching the bulbs it all works
InFaMouSLink
10-27-2015 06:51 PM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
