Installing an amp and sub to stock HU, help
Old Dec 21, 2004 | 03:44 PM
cgold79's Avatar
CGold
I just picked up a 2003 TL-P, and i want to install a box and amp. Crutchfield says that its very complicated and that i would need to tap into the speakers in the doors instead of the sub in the back. I was planingto disconnect the sub and wire the new amp and sub. Is this possible, is it recommended? can someone please advice. Thanks,
Old Dec 21, 2004 | 08:35 PM
DerrickM's Avatar
Speakers in the doors are already receiving a high-pass signal from the Bose EQ, so tapping into those won't work.
Some people tap into the stock sub speaker and are happy.
More work is to tap into the preamp signal going into the Bose EQ (coming out of the HU)--but that requires taking apart the dash, cutting into harnesses, and soldering.
I think your original plan would work and be fine. Be aware that you'll get automatic loudness, which will turn up your sub at low volumes.
james357
Feb 13, 2016 02:37 PM
handsom-hustla
Nov 13, 2015 05:04 PM
Abe_Froman
Sep 16, 2015 01:27 PM
