install DEI 530T with a Viper 791xv
Can someone help me out with installing this 530T automation module? I want 4 windows to go UP only when arming the vehicle. Thank you in advance...I only have one module. The store I bought it from says that the 530T takes the place of (2) 529Ts...is this true?
VP Electricity
1 Post
HEar it from the guy who wrote the original manual for the 530T when it was launched in the mid 90's (as an SmartWindows knockoff: )
A 530T takes the place of TWO 529s IF you had a 529 doing 2 windows UP and another doing 2 windows DOWN.
It can't do 4 windows up. It can do 2 windows both directions.
As far as installation, I suspect the TL-S uses the same window system as the TSX, but there's two kinds.
One kind has relays inside the switch, the switch has big wires going to the motor, and power and ground, but no other big wires coming in or out. For this kind you need to run wires into the door and grab the wires between the switch and the motor.
The other kind has big wires between the windows switches as well. For that kind, you can grab all the wires in the kick panel except for the driver's door where you have to go in.
If you can get the Helms wiring page for the car that would help a lot to ID the system.
cycdaniel
12-17-2019 10:58 AM
pistacio
09-26-2015 09:45 AM
