Inline driver
Inline driver
Does anyone know a good inline driver that I can use to amplify the signal that goes into the AUX input? I have it connected using the SNHONDA3, but the sound is not quite loud enough.
Also, will an inline driver give me more ground noise?
Thanks...Kenny
Thanks...Kenny
I got the Visonik VLD20 off of eBay a couple of weeks ago. I'm very happy with it. I set the gains on the driver to about 50%, thus I was able to drops the gains on my amp to about 15%. Sounds really good now.
Also, I have NO engine noise now. Before with just the GLI, I had some noise. But its gone now after adding this thing.
The only problem that I had with it was that its a bit on the big side, so you really have to find a good spot for it to fit behind the top compartment.
Thanks for the response!
Where did you mount this thing?
I looked at it on ebay and it does indeed look big.
Did you mount it behind the glove box or something?
Thanks...Kenny
Thanks...Kenny
I ended up fitting it behind the compartment above the "not an ashtray". But it was a bitch.
Look around though. The Phoenix Gold (forgot the model) is a good one as well and a bit smaller.
joflewbyu2
Aug 18, 2019 10:38 PM
xsilverhawkx
Sep 28, 2015 06:51 PM
