TSX: I need help with the HU harness to update 2008 tsx
Old Apr 7, 2010 | 02:07 PM
montclair's Avatar
6th Gear
I need help in updating my 2008 tsx audio,
I am new no flaming please.I hope this the right area for this
I need to upgrade the tsx amplifiers and speakers ,I am using older hifonics from my mazda for the fronts and rear door. the sub shall have its own amplifier.The install shops tell me that " clean sweep , or something along that line are required to install the new amplifiers and bring back lost sound " I realize this is not a requirement since the HU in the TSX is fine and the major problem is the balanced outputs, molex etc. Being in the Edmonton area the problem is all the shops seem to believe that a clean sweep is required . Hence I am here . From reading I know a balun adapter will work - I have found 2 links and would like to know if anyone has used these or if they shall work or any other ideas.
http://www.pac-audio.com/productDeta...&CategoryID=28
and
http://www.autotoys.com/x/product.php?productid=10770
As an aside this occured in one of the stores I went to in the past my son (at the time was about 12 or so ) . We into one of these stores and I noticed a square subwoofer - I enquired and was told I would not appreciate the "good sound" from this -the boy looked at me and said is he serious dad?
This was an interesting comment to both of us since I had two door mounted subwoofers in my 1987 aerostar and 2 *10 inch in the trunk of my 626
thanks .
Old Apr 7, 2010 | 06:01 PM
mercman's Avatar
Are you just adding a sub or do you want to replace the factory amp with aftermarket?
Jeff
Old Apr 7, 2010 | 07:00 PM
montclair's Avatar
6th Gear
thank you for responding Jeff, I am adding separates in the front , coax in the rear door . I have read the forums in the past and your harness or something similar would work . I have an active crossover (coustic? ) that the 4 unamplified signals would enter and cross over about 75 hz to the mains and the sub become active at about 40 hz and below . I have yet to calculate resonate freq of my car .
I am just about to bottle a stout I made.
TypeS860
Jan 10, 2026 11:11 AM
IBankMouse
Jun 13, 2020 12:53 PM
agupta3224
May 23, 2017 08:30 AM
johnalfa
Nov 5, 2015 06:44 PM
Eggs999bacon
Sep 24, 2015 10:08 AM
