I cant find this answer anywhere
Old Aug 10, 2001 | 05:12 PM
bigman's Avatar
'Big Daddy Diggler'
I looked all over the forum and coulsnt find the answer to this. I am getting an aftermarket ecplipse monitor/radio/cd/tape deck. I wanted to know if i use the aftermarket head unit, will i have any problems with the bose setup and most importantly to me, will i looe the navigation audio. I need the navi audio. Thanx.
Old Aug 10, 2001 | 11:48 PM
StanMan's Avatar
SE will probably need to clarify, but i believe the bose amps and speakers work in conjuction with each other so replacing the stock headunit should not be a problem. had you considered only replacing either the amps or speakers then that would have posed a problem since the impedance levels are unconventional. i also believe navi audio is funneled through the stock headunit so you might have to locate the proper outputs and attach an external speaker to it.
gatrhumpy
19
Dec 31, 2015 04:22 PM
BIGxRED
Oct 19, 2015 10:47 PM
Eggs999bacon
Sep 24, 2015 10:08 AM
eastcoastguy
Sep 23, 2015 06:29 AM
