How much power?
Old Jan 14, 2007 | 09:32 PM
ajbrickyard's Avatar
Question How much power?
I have a 2000 3.5RL and I want to add a sub and amp to the factory setup I have a alpine class D 400 watt to power the sub. Can the cars elec. system handle that without the lights blinking on every bass note?
Old Jan 16, 2007 | 07:55 PM
Acuraluvr's Avatar
Spinnin them beats
in short, yes
depending on the amp, a 400 wt amp will be ok for the car. My friend had 2 1200 wt amps to dual 15s the after about a month, the battery started to lower so he now has a 400 wt amp with a 12'' 1000 wt max sub
Old Jan 18, 2007 | 09:27 PM
dnd2984's Avatar
Yes it can handle it, but is that 400 watts max or RMS...
Old Jan 19, 2007 | 10:53 PM
It's 400 watts rms with a 2ohm load. Does anyone think/know if this is to much bass to add to the factory stereo it's just one 12inch woofer and it's the only upgrade to the factory bose system will it over power everything else?
Old Jan 20, 2007 | 12:49 AM
spiderman3098's Avatar
you should be fine plus u can always set up your bass level to match your speakers with the gain levels.
Old Jan 21, 2007 | 07:50 PM
dnd2984's Avatar
You will be fine. Just keep the box sealed and not ported
Old Jan 22, 2007 | 04:51 PM
Thanks. I was trying to decide wich way to go ported or sealed I was leaning toward sealed for the tight bass. thanks again.
Acura604
20
Aug 5, 2017 12:55 AM
spudweb
May 22, 2016 02:39 PM
knight rider
Mar 4, 2016 08:59 AM
mars
Sep 28, 2015 11:03 AM
95oRANGEcRUSH
Sep 25, 2015 12:50 PM
